granny gear?
Old May 13, 2010 | 12:12 PM
yzmoore's Avatar
yzmoore
granny gear?
I'm considering swapping out my shot RUG for a t-18. I really like the overdrive of the RUG but from what i hear they are worthless transmissions. I will be lifting the truck a few inches and putting 34 or 35 inch tires on it. My question is would i be able to use the low unsynchronized first gear of the t-18 all the time when starting from a stop. If i can do this i figure it would not be necessary to re-gear it. Basically can the granny gear be used like a normal 4 speed transmission? I was also thinking with larger tires and not re-gearing i would gain my overdrive back. Would it be a good idea to use the transmission in this way? Thanks, Josh
Old May 13, 2010 | 12:25 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
I always (unless rolling downhill) idle off in first and go right to second!
I don't like replacing clutches.
-Enjoy
fh : )_~
Old May 13, 2010 | 12:45 PM
f100jim's Avatar
f100jim
I don't know how hard they are to find, but you may like the T19 too. 1st is synchronized and it came (in Fords) in 3 flavors:
ratios:
4.02, 2.41, 1.41, 1
5.11, 3.03, 1.79,1
6.32, 3.09,1.68,1 (same as T18)
In all flavors, R is 6.96 (compared to 7.44 for the T18)
If you go junkyard hunting for one, the T19 looks a lot like the T18, but it has a PTO port on both sides, the T18 has PTO on pass side only.
Old May 13, 2010 | 02:12 PM
Ken Blythen's Avatar
Ken Blythen
What ratio is your rear axle?
Old May 13, 2010 | 02:31 PM
yzmoore's Avatar
yzmoore
I'm not exactly sure. I just picked it up a few days ago and still figuring stuff out about it. The axle code is 19 and its an 83.
And thanks for info guys sounds like it might it work pretty good
Old May 13, 2010 | 02:58 PM
82F100SWB's Avatar
82F100SWB
Axle code 19 is 3.55. 35's will get you back reasonably close to what stock cruise rpm would have been with the O/D box and stock tires.
The T19 is a 460 and diesel only unit from the factory, with the 4.02 version being common behind 6.9's. They're a little harder to find, but, they are a good unit.
Both my 460 and 6.9 had the 5.11 gearset in them stock. According to a Ford TSB it was only the 83 and early 84 6.9 trucks that got the 5.11 gearset, but the tag on my 6.9's transmission points to an 86 build date and it being the factory transmission.
Old May 13, 2010 | 04:28 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4
Ditto on the T-19... I have both a T-19 and NP435 (un-sync'd 1st). I never realized how nice it is to able to shift into first without not having to come to a complete stop until I picked up my '86!
Old May 14, 2010 | 11:48 AM
yzmoore's Avatar
yzmoore
Well i went and just picked up a t-18. Thats all there was at the junkyards around town and it was only 90 bucks and it looks good and feels good so i went ahead and pulled it. Maybe if i find a t-19 down the road ill grab it but this should work for now. Is there anything i should to do the transmission besides change the fluid out before i put it back in? Also what should i put in it? just 80-90w gear oil? Thanks, Josh
Old May 18, 2010 | 11:34 PM
f100jim's Avatar
f100jim
You might want to replace the front (input shaft) and rear (slip yoke) seals while it is out. They are pretty cheap. Easy to change now, PITA later :-)
Old May 19, 2010 | 12:25 AM
6fifty_f1fifty's Avatar
6fifty_f1fifty
I'm doing this swap right now, boy what a pain it was to get the t-18 in. It is so much heavier than the rug it isn't funny.
I don't know what your setup is, but you may find when you put it in that you have to turn the tranny crossmember around to accommodate the t-18.
edit: and I am going to put valvoline 90 wt in mine...
Old May 19, 2010 | 11:28 PM
yzmoore's Avatar
yzmoore
Well i got the t-18 in. It ended up taking forever though. I went ahead and put in a new rear main seal which was a pita. It the two piece one that you supposedly have to to take off all the main bearing caps and lower the crank a little to put it in. But luckily i just had to take off the one cap that holds the seal and was able to just push the new one through. Got rid of a lot of vacuum lines and the air pump. With all that it ended up taking me and a buddy a solid 20 hours over two days to get it done. But that is including the 50 trips to the parts store for random stuff i needed. But it drives really good now and the transmission works great. I was a little worried about using a junkyard transmission. 6fifty my crossmember actually ended up bolting right up. Not sure if yours is 4x4 or not but mine is and maybe thats the difference?
Old May 19, 2010 | 11:34 PM
6fifty_f1fifty
yeah mine wasn't 4x4. plus, due to my driveshaft length and not wanting to change that, I got a t18 with a 12" tailhousing.
Old May 20, 2010 | 05:01 AM
Ken Blythen
Do you know which version T18 it is (low gear ratio)?
How do you find the jump between 3rd - 4th?
Old Sep 30, 2010 | 01:46 AM
csw's Avatar
csw
just got a 87 f150 4x4 on a 4" lift with 35" tires and i find that its starts off much better in 1st (granny gear) than in 2nd. does this have to do with the tire size?
Old Sep 30, 2010 | 03:26 AM
Ken Blythen
Tire size & axle ratio
