Number please
Old May 13, 2010 | 10:38 AM
OldHarley's Avatar
OldHarley
Number please
I am replacing some aftermarket chrome valve covers with stock 1965 ones on my 352 and I need to replace the rubber PCV valve retainer grommet on the RH side cover.
I am coming up with a part number of B8A-6A892 from last page of Sec 60.7. It is hard to decipher the parts list and my local Ford partsman is clueless, since his catalogs only go back to 1982 (he says), however, he can search by numbers, but can not find the number above.
I think if I had the correct number I could go from there. Or, if someone could check, I am relatively close to some local obsolete sources such as Parts Int'l in Farmers Branch, TX. or Antique Auto in Arlington. TX.
NAPA, Autozone and O'Reilly have no listing at all for this application.
Could someone assist?
Thanks
Old May 13, 2010 | 01:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I am coming up with a part number of B8A C8AZ-6A892-A from last page of Sec 60.7.
In-correct for 1965/67's. This grommet fits into the oil cap of 1968/76 FE's.
A 90 degree plastic elbow (C8AZ6767A) fits into the grommet, a smog hose fits onto the elbow, then routes to a nipple on the air cleaner.
C7AZ6A892B (replaced C7AZ6A892A) .. Retainer (rubber grommet) ~ Retains Smog Valve in Valve Cover / Obsolete
For 1965/66's, you have to look up this grommet in the catalog under the listing for the valve cover (6582) / Section 60.7, Page 10.
Fits: 1965/72 F100/350 352/360/390 / 1965/67 Passenger Cars 352/390/410/428.
C7AZ6A892B =
GREAT CAESARS GHOST! No one in TX has any.
HAVEN FORD SALES in Haven KS has 1 = 800-748-7803.
NOS PARTS SOURCE in Lenexa KS has 1 = 913-220-5746.
TISON MOTOR CO.in Estill SC has 1 = 803-625-2551.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 91 = 704-786-8139.
GREEN SALES CO. in Cincinnati OH has 214 = 800-543-4959.
C7AZ6A892A =
NOS PARTS SOURCE has 1.
"High Buck" BOB ALLEN FORD in Overland Park KS has 1 = 800-676-0675.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 800-546-7278.
C7AZ6A892A & B are identical. Ford changed the part numbers suffix when they changed the package quantity.
Remember the 1950's Superman TV show? GREAT CAESAR'S GHOST! was the catch phrase of the Daily Planet's editor, Perry White.
Old May 13, 2010 | 01:47 PM
OldHarley's Avatar
OldHarley
I don't think I have EVER heard anyone (else) use that phrase since the show went off the air!!
Come to think of it, I don't think I've ever heard the reference to dead as Julius Caesar except you! which is why I replied the way I did.
The reference you indicate - I would NEVER have found. If I did, I would not have likely realized the ret. (as abbreviated) was the part I needed.
Since you have looked (I believe), I would guess I don't need to contact local Ford dealerships for this part.
Thanks
Old May 13, 2010 | 02:01 PM
NumberDummy
You've prolly heard it, but don't remember it.
"He's as dead as Julius Caesar" = spoken by Sean Connery in the film "The Untouchables."
You can contact your local dealer for this part, but...since it's obsolete, they won't have it, can't order it. Basically...the part number is as dead as Julies Caesar!
I found the grommets by running the part number on the in-house Ford Dealer Parts Locator System (no dealer in TX has any) and the obsolete parts vendors website (no one in TX has any).
The grommet is illustrated here: Illustration Section 66.3, Page 2, lower picture.
Old May 25, 2010 | 10:49 PM
OldHarley's Avatar
OldHarley
I ordered the rubber retainer C7AZ-6A892-B from Dennis Carpenter Obsolete.
When it came it had part number C7AE-6A892-A molded into the rubber and WAS NOT the correct part (even tho I did order correct number).
DC says my part number C7AE-6A892-A is bad, but it appears to be genuine FoMoCo. They say if I send it back, they will refund my money, but shipping is, of course, more than the $7 part.
Could this be a molding error, or is there such a part? Not that it really matters, I just did not like DC telling me the part number on a Ford part I had in my hand was bad. BTW, I have checked and double checked and the questionable E (and suffix A) is there on the part.
Old May 25, 2010 | 11:53 PM
NumberDummy
Great Caesars Ghost!!
Numbers marked on parts after 1956 are FoMoCo ID Engineering numbers, not actual FoMoCo part numbers.
ID number C7AE-6A892-A = Ford part number C7AZ6A892A replaced by: C7AZ6A892B
Old Jan 6, 2013 | 09:10 PM
72Truckin's Avatar
72Truckin
So if that part is just a grommet to retain a smog valve, would it be ok to just cap this valve cover?
The same grommet on my passenger side valve cover needs to be replaced, and I was trying to source the replacement part; however, it is hard to find.
I found one on ebay, but it cost ~$50: Ford 428CJ Boss 302 PCV Valve Grommet C7AZ 6A892 B | eBay
This specific grommet has grooves on the bottom that are needed to fit into the valve covers I have.
Old Jan 6, 2013 | 09:21 PM
1972RedNeck's Avatar
1972RedNeck
The rubber insulators (motor mounts) on the bell housing of my '66 ford have the actual part number, not engineering number molded in them.
Were they used prior to '56 so they all had the numbers stamped in them?
Old Jan 6, 2013 | 10:24 PM
72Truckin's Avatar
72Truckin
My truck is a '72 F250 390, woth Shelby valve covers
Old Jan 7, 2013 | 04:02 AM
NumberDummy
Originally Posted by 72Truckin
C7AZ-6A892-B (replaced C7AZ-6A892-A) .. Retainer (rubber grommet) ~ Retains Smog Valve in Valve Cover / Obsolete
How many would'ja like?
I doubt if bought from either of these two sources, the price of this grommet will be 50 bucks. That's outrageous!
C7AZ-6A892-B .. PCV Valve Cover Grommet.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 93 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 192 = 800-543-4959.
MUSTANG'S ETC. in Van Nuys CA has 28 = 818-787-7634, but they usually want MEGA-BUCKS for obsolete parts.
If you live in the LA area, call Bo @ Mustang Service Center in North Hollywood (818-765-9266), he may have some. Bo is an ex Ford partsguy.
In the mid 1970's, Bo and I worked at the Ford dealer in WLA.
Old Jan 7, 2013 | 05:43 PM
OldHarley's Avatar
OldHarley
Senor Numbers Dummy,
The eBay auction for the C7AZ-6A892-B evidently is what the book says is correct for a 1966 352 truck as seen in the auction listed above:
Based on the date of my original post, after a year and a half, I still have not been able to find the one for my truck. My rocker covers seem to be 1965 vintage and were originally gold painted. They are definitely for a 352 motor and have a simple 1 1/4" round hole in the passenger side rocker arm cover. Unfortunately the retainer was so brittle it broke into pieces when I removed it for painting (glued back together for the picture):
The lugged retainer seems to be the correct one by the book, but obviously it ain't what I need!
Sure wish I could find a replacement, but still have no clue to the number. I actually went to a hardware store and bought a 1 1/4" grommet with a 3/4" hole that sorta works, but it is not quite thick enough to properly retain the PCV valve in an upright position.
If you have any other ideas on what this could be off of so I can find one, I would be obliged if you would let me know.
Thanks
Old Jan 7, 2013 | 06:58 PM
72Truckin's Avatar
72Truckin
Like this?
1960-1965 6 CYLINDER PCV GROMMETS - Valve Covers - Falcon Enterprises
Old Jan 7, 2013 | 08:09 PM
72Truckin's Avatar
72Truckin
I just installed my new oil filler breather cap, and the truck sounds healthier!
The previous cap did not allow fresh air into the valve cover.
I read that these old trucks came with breathable oil filler caps, and that is what helps the truck circulate fresh air with the recycled air from the pcv valve, on the other valve cover.
Is there a reason why a non-breathable oil filler cap would be used in place of a breathable cap?
Old Jan 7, 2013 | 08:32 PM
hiball3985's Avatar
hiball3985
The previois cap did not allow fresh air into the valve cover.
I read that these olf trucks came with nreathanle oil filler caps, and that is what helps thr truck circulate fresh air with the recycled air from the pcv valve, on the other valve cover.
None that I can think of, you need fresh air going in.
Old Jan 7, 2013 | 09:38 PM
OldHarley's Avatar
OldHarley
Yes, same configuration, except I think that one is too small. The referenced site does not list factory numbers, but I believe that one is a C8SZ-6A892 which only fits the 170 and 200 sixes, like you would find in a 1965 Mustang.
Still, thanks for looking.
