75 to 79 column wiring
Old Feb 1, 2003 | 05:16 PM
78f250lj's Avatar
78f250lj
Question 75 to 79 column wiring
Hello,
I have a '75 wiring harness and a '79 3 speed column. There are more wires on the '79 column than there are on the '75 harness. Does anyone have a breakdown by color of what each wire does in the '75 harness and the '79 column? I looked through the past threads here and in the wiring forums but couldn't find what I needed. Any help is appreciated. I also have a Haynes manual, but it doesn't show a breakdown of the column and I looked in my shop manuals and couldn't find a diagram either.
Thanks,
Lenny
Old Feb 1, 2003 | 11:05 PM
Torque1st's Avatar
Torque1st
Posting Legend
Buy one of the OEM manuals available here on CD-Rom to get good wiring diagrams.
Old Feb 2, 2003 | 12:45 AM
sparky's Avatar
sparky
If you list the colors of each I may be able to help
Old Feb 2, 2003 | 01:53 AM
Torque1st's Avatar
Torque1st
Posting Legend
Thanks Spark!
I don't have any wiring diagrams for these beasts.
Old Feb 2, 2003 | 03:28 PM
78f250lj's Avatar
78f250lj
OK, I went out and lokked at my wires and heres what I've got:
On the 75 column harness going from left to right:
BLANK, RED, BLUE, LIGHT GREEN, YELLOW w/BLACK STRIPE WHITE w/RED STRIPE, BLANK.
In the row below the above:
LIGHT GREEN & DARK GREEN (DARK GREEN HAS WHITE STRIPE), WHITE w/ BLUE STRIPE, BLUE w YELLOW STRIPE, RED w WHITE STRIPE.
OK, now on my 79 column I have the following color wires ( going left to right)
YELLOW w/ BLUEISH DOTS ON IT, WHITE w/ PINK STRIPE, GREEN w/ ORANGE-BROWNISH STRIPE, ORANGE w/ PURPLE STRIPE, LIGHT BLUE, LIGHT GREEN, BLANK.
BLANK, DARK BLUE, WHITE w/ BLUE STRIPES, DARK GREEN w/ LIGHT GREEN STRIPE.
I hope this helps. I really don't wanna trace every wire.
Lenny
Old Feb 2, 2003 | 10:39 PM
sparky's Avatar
sparky
BLANK
RED - how about red with black stripe - 12volts in for brake lights
BLUE - 12volts in for turn signals
LIGHT GREEN - out to RH rear stop/turn light
YELLOW w/BLACK STRIPE - out to LH rear stop/turn light
WHITE w/RED STRIPE - 12volts in for emergency flashers
BLANK.
LIGHT GREEN & DARK GREEN (DARK GREEN HAS WHITE STRIPE) - out to LH front turn signal
WHITE w/ BLUE STRIPE - out to RH front turn signal
BLUE w YELLOW STRIPE - out to horn relay
RED w WHITE STRIPE - ??? I know this one I just cant find it
It may just be my diagrams but those colors for the 79 column do not make alot of sense
Old Feb 2, 2003 | 11:47 PM
Mil1ion's Avatar
Mil1ion
Head's up !!!!
If you were to search through this forum ,you will find a couple of threads that I have posted diagrams,colour coding,illustrations, and pictures of what Exactly what you are looking for.
Go to search and type.
Steering Column wiring
or Turn Signal wiring.
Old Feb 3, 2003 | 08:53 AM
78f250lj's Avatar
78f250lj
Before I even started this post I did a search and could not find what I needed. All i want to know is what each color wire does on the 75 harness and 79 column.
Lenny
Old Feb 3, 2003 | 02:36 PM
Mil1ion's Avatar
Mil1ion
I just found 3 threads.
https://www.ford-trucks.com/forums/s...der=descending
Bruners4
Feb 9, 2015 11:53 PM
Haastyle
Mar 7, 2011 09:28 PM
rhino3
Jun 19, 2005 09:34 PM
rick
Feb 23, 2000 10:43 PM
