Sponsored by: Real Truck
2003 engine
Old May 12, 2010 | 08:47 PM
Walt62's Avatar
Walt62
2003 engine
I have a 2003 F250 super duty the engine is knocking It's a 5.4 L efi.
my questions are
1 how can I tell if it has 2 or 3 valves ?
2 I was tolld if it has 3 valves it might be a senser ?
Thanks Walt
Old May 12, 2010 | 09:03 PM
Darrenigel's Avatar
Darrenigel
A 2003 is a 2 valve. The 3 valve came out in 2004
Old May 13, 2010 | 07:44 AM
edjunior's Avatar
edjunior
Actually, the 3 Valve for the SuperDuty didn't come out until 2005! Regardless, you have the 2 valve.
Old May 13, 2010 | 10:45 AM
TennesseeMustangPerf's Avatar
2V motors also have a knock sensor, but that will not cause the knock. Is it doing this all the time, throughout all RPM ranges?
Old May 13, 2010 | 03:52 PM
Walt62's Avatar
Walt62
At first it was when I started it now its more often
Old May 14, 2010 | 08:00 AM
SBastow's Avatar
SBastow
If its when you start up, what kind of oil filter you have? Motorcraft oil filters will solve the start up problem.
Old May 14, 2010 | 09:02 AM
GUNNERDOG's Avatar
GUNNERDOG
I think the 3v came out in the 2005 model year, but was available in the fall of 2004. So your both right!
Back to the OP, do you have a check engine light? If so, what are the codes?
Old May 14, 2010 | 09:20 AM
Darrenigel's Avatar
Darrenigel
The 3 valve came out first in the 2004 f150. Then in 2005 it was put in the Super Duty.
I should have been clearer in my first post. I really didn't think there was a reason to post a response because we were both correct.
Old May 14, 2010 | 07:57 PM
Walt62's Avatar
Walt62
I dont have a check engine light with codes when idoling you dont hear the knock but at 1750 rpm its there constently
