Hi everyone
Been awhile since I was able to go on here. how is everyone?
Well I drove the truck for about a hour or two and then shut the engine off when home. Then ten minutes later moved it 100 feet shut it off and then it wouldn't start until the third key turn. The instrument panel said check gauges. It was almost like the starter would spin a couple times and then stop rough for the first two times.
Dirty throttle body is a fairly common issue. When the butterfly sticks it throws some significant hiccups in the pcm. Pull the codes. If a TAC (throttle actuator controller) comes up, clean up your TB. Do a search. There are a few threads pertaining to that issue.
Wow '06 with 21K. Take her out and turn her loose once in a while.
