king pin fun
Old May 12, 2010 | 02:05 PM
bigtiny2020's Avatar
bigtiny2020
king pin fun
ok so i am about to redo the kingpins on my 64 f100 and i open the box to find that i have lost 2 of the little nylon rings. anyone know where i can get replacements with out rebuying the whole kit?
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old May 12, 2010 | 03:58 PM
camperspecial65's Avatar
camperspecial65
are you talking about the cylindrical rings or ??? If its a NOS kit, depending on the part, you MIGHT MIGHT MIGHT get lucky and find them by themselves, but thats a HUGE shot in the dark...
In looking at my NOS kingpin kit for my 65...the only ring type things would be the bushings themselves or the bearings.
- cs65
Old May 12, 2010 | 08:26 PM
ul37's Avatar
ul37
if your missing the nylon bushings and they are the same diameter as the 65 bushing(which i beleive they are).i should have some i could send to you.i wil check when i go to work tomorrow.
joe
Old May 13, 2010 | 01:36 PM
bigtiny2020
they are the rings that go on either end of the king pin. yeah they are cylindrical.
Old May 13, 2010 | 02:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by bigtiny2020
they are the rings that go on either end of the king pin (not the nylon bushings). yeah they are cylindrical.
B7C3125A .. Spindle Bolt Dust Seal / Obsolete / Fits: 1957/64 F100/250.
AITKEN MOTOR CO in Aitken MN has 2 = 218-927-2169.
NORTZ & VIRKLER FORD in Lowville NY has 10 = 315-376-6594.
LYLE'S FORD-MERCURY in Eagle Grove IA has 12 = 800-397-6319.
GREEN SALES CO. in Cincinnati OH has 26 = 800-543-4959.
Squire Don: If'in you had looked in your parts catalog (Section 30, Parts List 30.1B)...instead of at your king pin kit, you wooda discovered this part was not used 1965 and later, and...
Here's 50 of them....so "HUGE shot in the dark" doesn't apply.
btw: 1965/70 F100/250 Twin-I-Beam parts are listed in Section 30, Parts List 30.2A
Old May 16, 2010 | 09:19 PM
Big Daddy T's Avatar
Big Daddy T
dont buy the nylon bushins. buy the matl onrs and have them reamed to match your king pins. they will last much longer!
Old May 16, 2010 | 09:50 PM
garbz2's Avatar
garbz2
There are no such thing as nylon bushings for 61 to 64 axles. 65 up can use the derlin plastic bushings and do not require reaming. They wear out faster and require grease every three months just like bronze bushings. You pseudo parts book worms really need to look in to the question before rattling off an answer. ND had it spot on the rest need a bit of polish.
Where did you purchase it? take it back or call customer service and get a new set. NAPA jobber stores will have a selection of O rings as will Mcmaster carr or grainger
Garbz
Old May 17, 2010 | 01:53 AM
NumberDummy
Originally Posted by garbz2
There are no such thing as nylon bushings for 61 to 64 axles. 65 up can use the derlin plastic bushings and do not require reaming. They wear out faster and require grease every three months just like bronze bushings. You pseudo parts book worms really need to look in to the question before rattling off an answer. ND had it spot on the rest need a bit of polish.Garbz
I'm not sure what the OP wants. He says the missing parts go on either end of the king pins...these are the round dust seals I listed in post #5.
1957/64 F100's use the same king pins....with bronze bushings.
Old May 17, 2010 | 04:11 AM
bigtiny2020
yep i am missing 2 of the dust seals. they were there when i got the set, the parts store i got it from has since closed. i was wondering what would be ok to use, can i just run to napa and get some o-rings that match my dust seals?
Old May 17, 2010 | 09:25 PM
santi2322's Avatar
santi2322
This is what you are talking about right? I'm not sure if you can get them seperate... I would just go down to the parts store and see what you can find.
Old May 18, 2010 | 01:58 AM
NumberDummy
<INPUT id=gwProxy type=hidden><!--Session data--><INPUT id=jsProxy onclick=jsCall(); type=hidden>
See post #5...I found FIFTY of these dust seals NOS.
