Sponsored by: Real Truck
2000 F250 Wiring
Old May 12, 2010 | 01:48 PM
ncboy34's Avatar
ncboy34
2000 F250 Wiring
The other day while wiring a bumper pull trailer for lights I noticed that my left brake lights and left turn signal would not come on. To check the wiring on the trailer I hooked it up to another vehicle and everything worked fine. This is for a 4 pole hookup. To me this says that I have a problem with the wiring on my truck for the 4 pole trailer hookup. What do I need to do to fix this. I would really like to avoid messing with a dealership. It is a 2000 F250.
Old May 12, 2010 | 02:01 PM
SteveH-CO's Avatar
SteveH-CO
I would buy a debug plug at Walmart for $4 (the trailer ligh test plug with LEDs in it, used for debugging trailer light problems). Anyone with a tow vehicle should have one of these for isolating trailer light problems. Using it is much easier than hooking up a trailer to test the lights.
Then check the bulbs in the truck. Then check fuses. Then look for physical damage to wiring that feeds those lights.
Old May 12, 2010 | 02:12 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
It's becoming more and more common to find corrosion inside the 7-way/4 way plugs at the rear of the truck..... open them up and take a look.....If you have a meter OR a simple test light check these wires. Use the ground pin as a ground and if no light, use a frame ground. If that works, the ground wire in the plug is broken.
GRNMSTR
2004 - 2008 F150
Apr 16, 2010 09:34 AM
loudfords
All Things Towing
Jun 19, 2008 03:01 PM
wgouldin
Sep 4, 2007 04:34 PM
silverfrost99
1978 - 1996 Big Bronco
Jul 1, 2005 07:23 AM
zr440man
Jun 15, 2005 02:03 PM
