C6 Transmission woes
Old May 12, 2010 | 12:46 PM
zdfoster's Avatar
zdfoster
Hey all, I'm new here, but have been lurking for a little and have been learning a lot. So thanks!
I have a '72 F100 with a 360, with a C6. I took it to a mom&pop shop to have them replace the torque converter and they screwed me bad, so now I have a few issues...
-1 they cut the support that bolts to the frame below the pan
-2 they some how broke off a section of the bell-housing. And of course it's right where it bolts to the block. So it's only hanging onto the block via 1 bolt!
SO, that is what I'm left with. I'm trying to pick up the pieces, and I'm wondering a few things.
-Looking at tracking down a few other C6, but will any C6 bolt up to my 360 block?
-Is now a time to be looking at a different transmission? I drive her maybe once a week, and on weekends to haul stuff.
-Where the heck do I find a replacement for that brace? Not even sure what it's called?
Thanks for any help you can send my way.
Old May 12, 2010 | 02:57 PM
Danger_Dave's Avatar
Danger_Dave
what you need to be doing is going after them. call them multiple times, go down there in person and talk to them. show them. take pictures. send them a letter, and finally file a lawsuit in small claims court against them because places like that need to be burned to the ground, and all the snakes need to be stomped. but it sounds to me like you are way too passive about the whole thing?
Old May 12, 2010 | 03:10 PM
zdfoster's Avatar
zdfoster
trust me... already been doing that. They closed down shop cause the owner died!
As ticked off as I am, I'm not the type to go after a widow who just lost her husband.
I've learned my lesson about using a small mom & pop shop. Just nothing really that I could do other then bring the law into it. Which just doesn't really right.
In a few years I would have needed a new transmission anyway... so it's just forcing my hand a little early.
Old May 12, 2010 | 09:45 PM
biggut's Avatar
biggut
The C6 you need is specific to the FE engine; 352-360-390. The bellhousing is different on one from a small block. I'd find a used one in the wrecking yard- they'll usually guarantee them for enough time to find out if it's any good.
If it's the crossmember they cut; you probably should get it welded right away. It's there for a reason.
As far as going after the widow; this guy's estate can still pay for the damage. It's business-she'll get over it. You didn't do the dastardly deed.
Good luck
Old May 13, 2010 | 04:38 AM
jowilker's Avatar
jowilker
ZD, It's not mom & pop that is the problem, many small businesses are very well run. Hate to say it but maybe you didn't check them out like you should have before you left your truck there.
Anytime that you are dealing with any business that takes payment for service rendered you have a right to expect them to be able to complete the task without damages. The business is liable, if they are broke and the widow can't pay restitution then walk away, but they should have liability insurance that you can collect from not her.
The C6 tranny cases are different at the bell but the same down the body. Parts swap between them.
Cross members should be the same between like trucks, so finding a replacement should be easy enough.
Check with an attorney to see if the business had insurance.
John
slimguy379
Jun 15, 2014 11:23 AM
bsiebert
Sep 23, 2010 07:47 PM
Travsuw
Apr 23, 2009 12:41 AM
71LTD390
Apr 17, 2004 10:33 AM
