Sponsored by: Real Truck
Key for spare tire?
Old May 12, 2010 | 10:16 AM
texasjack's Avatar
texasjack
Key for spare tire?
Where can I get key for spare tire holder under back of truck on my F350 ? thanks
Old May 12, 2010 | 10:21 AM
redford's Avatar
redford
FTE Leadership Emeritus
It is a dealer only part.
Take your truck down and tell them you're missing the key. Most dealers have a collection of them so they can try each and tell you which will fit.
Old May 12, 2010 | 10:58 AM
texasjack's Avatar
texasjack
thank you!!
Old May 12, 2010 | 11:09 AM
cartmanea's Avatar
cartmanea
Go to the dealership, ask to use their master set to find which key yours is. After you find which number it is, go to mcgard.com to get their customer support number, and you can order a new one for around $25.
Old May 12, 2010 | 12:37 PM
jh225's Avatar
jh225
Or if the spare is off as mine was, you can remove the winch from the truck, pull the key part out (it is just held by a spring clip) and weld a 3/8 square drive to the end of the extension arm. The back end of that lock is just a square drive.
No more key needed.
Old May 12, 2010 | 01:11 PM
MC9's Avatar
MC9
Too much work, just pry off the end clip and from then on just use the jack extension without the key. There are 16 different "keys".
ostrx250
Apr 27, 2013 08:34 AM
crawdad
2004 - 2008 F150
Jul 17, 2012 12:06 PM
UaVaj
Apr 2, 2009 09:08 AM
indebt
13
Feb 18, 2009 02:40 PM
