no start!
Old May 11, 2010 | 08:07 PM
2020's Avatar
2020
no start!
OK,We changed oil in the old truck Sunday and she wouldn't start afterward.I finally sprayed a little ether and she fired up.Started Ok Sunday when my son went to his GF's and back and yesterday to school and back.This afternoon when he was leaving baseball practice,it wouldn't start and he had to spray again.I checked fuel press. at the lift pump-5-6lbs.-I checked press. at the schader valve on top of the filter and got about 2 1/2 lbs.Is that from the return lines on the injectors? Is that OK?It started several times OK but that is twice since Sunday after sitting for a few hours.Any ideas?
Old May 11, 2010 | 08:15 PM
joe f350's Avatar
joe f350
any pools of fuel on the engine
Old May 11, 2010 | 08:17 PM
johnboggs21's Avatar
johnboggs21
you want to get 1/3 of a pint of fuel at the filter head for 10 seconds of cranking, and 5-7 psi IIRC.
Old May 13, 2010 | 04:46 AM
2020's Avatar
2020
I changed the piece of rubber line from the frame to the pump just because it looked old.The 2nd injector on the right side(#2 ?)was a little wet around the plastic return hat so I pulled the return lines off that side and checked the o-rings.They looked good but I put new ones on #2.I think it's getting air in the system but I also wonder if a failing IP would let the injector lines empty and get air in them.When it does this it runs fine when it starts,it doesn't start rough and then smooth out.
Old May 13, 2010 | 11:12 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
You would be best off to put a complete Injector Installation kit in ... Doing Injector returns one at a time is a tail chasing nightmare and you'll likely never get them all sealed, as you change one you'll move another causing it to leak.
Do all 8 at once, or at least one whole bank.
Remember Air Molecules are smaller then Diesel Molecules, just because it's not leaking fuel does not mean it's not leaking air.
-Enjoy
fh : )_~
Crobinson
Jan 1, 2014 12:27 PM
Motorsportsartist
1983 - 2012 Ranger & B-Series
Aug 6, 2010 03:18 PM
IndySilverAnny
Jan 5, 2005 09:44 AM
taurus8
Electrical Systems/Wiring
Oct 1, 2003 10:38 AM
JTY
Jun 12, 2002 11:54 AM
