1994 F150 issues
Old Dec 28, 2013 | 01:29 PM
Crobinson's Avatar
Crobinson
1994 F150 issues
I have a 1994 Ford F150 with a 300 6-cylinder. While on my way to church last Sunday the truck just quit on me like it ran our of gas. I smelled electrical as soon as it done it. The truck will turn over but not start so I guessed it was the fuel pump. Checked the fuse, it was good. I checked the relay and it was clicking ok. So I dropped the fuel tank and pulled the fuel pump out. I jumped it straight to the battery and it ran but when I plugged it back to the harness it wouldn't run. So where do I go from here. I think the truck used to have duel tanks before I got it. Master mechanic is not my name so a lot of description will be necessary. Thanks
Old Dec 28, 2013 | 02:31 PM
kermmydog's Avatar
kermmydog
Did you check the fuel cut off switch to see if it tripped out? It is located under the right kick panel. There is a little dip on the top of the panel to push the reset.
Old Dec 28, 2013 | 03:26 PM
subford's Avatar
subford
Sounds like your PCM Computer burned up.
Old Dec 28, 2013 | 04:46 PM
Lead Head's Avatar
Lead Head
Does your check engine light come on when you turn the key on?
Old Jan 1, 2014 | 11:44 AM
Crobinson's Avatar
Crobinson
Well there it is
Folks I appreciate the advice and help. It was the PCM that burned up. That thing was aggravating to get out. Now should I save money and buy used or just get a new one?
Old Jan 1, 2014 | 12:27 PM
Lead Head's Avatar
Lead Head
Don't waste your time with used unless it's real cheap, like <$25.
midnightwolf
Apr 8, 2017 09:29 AM
fordtruckfriend
1997 - 2003 F150
Nov 25, 2006 07:00 PM
John7894
13
Feb 19, 2006 11:00 AM
BigA_02
Aug 11, 2003 07:52 AM
Klangmire
Mar 26, 2003 08:54 PM
