ENGINE RECOMENDATIONS
Old May 12, 2010 | 12:13 PM
HIO Silver's Avatar
HIO Silver
Go Big
A 460 budget build with a few upgrades can put out about 490 HP and a buttload of torque. Go big and you won't be disappointed...
Old May 12, 2010 | 05:17 PM
gus11208's Avatar
gus11208
If you unplug 2 sparkplug wires on a 460 thats what a360- 390 runs like. The sky is the limmit with a 460 you can build a nice torker to somthing scary its all in how much money you want to spend. Its worth it
Old May 12, 2010 | 05:37 PM
Rockstone's Avatar
Rockstone
Too funny, I've had and like both, but I will always have an FE.
Old May 12, 2010 | 06:31 PM
bamaf150's Avatar
bamaf150
lol, I was just stirring the pot but I will say this, my '87 stock 460 didnt pull any better than my old '73 360
Old May 12, 2010 | 09:27 PM
jeremychance's Avatar
jeremychance
Well it seems to be a showdown between 390 and 460. But the 460 guys look to be pulling ahead!
Old May 13, 2010 | 06:08 AM
Redneckryder's Avatar
Redneckryder
I like the 400....<assumes defensive position> :-)
Old May 13, 2010 | 04:32 PM
1993topdog's Avatar
1993topdog
V8? Go with the 460. Pound for pound, it'll get better mileage and power than all of the other ford "bigblocks"... Yea, yea, it know Ford never made any big blocks...just different engine series.
Personally, I think the 300 is tough to beat for an all around perfect truck engine. That's what i'd go with... and there's plenty of aftermarket support for the I6's if you want more power/performance
It's all in what you plan on doing with the truck.
Old May 13, 2010 | 04:54 PM
1cdccop's Avatar
1cdccop
Doesn't the 460 require a different bell housing and motor mounts than a FE engine? If so, would the gain in horsepower over the 360-390 be worth the money?
Old May 13, 2010 | 05:04 PM
1993topdog's Avatar
1993topdog
460 bellhousing is different than 360/390. 460 shares the same bellhousing with the 351M/400, and finding one shouldn't be too difficult.
if power (HP & torque), you can't beat the 460. I think it's worth it.
Old May 13, 2010 | 09:16 PM
Carver Speed's Avatar
Carver Speed
Do the 460. I hated my FE motors, the heads, the intakes, the mileage, I love my 460's I'm running three of them presently.
Old May 13, 2010 | 09:24 PM
bamaf150's Avatar
bamaf150
3 460s,lol, do you own stock in exxon mobil?? Seriously though, mileage, how much better could a 460 be than an FE? 12mpg instead of 10?
Old May 14, 2010 | 08:33 AM
1993topdog's Avatar
1993topdog
maybe not that much mileage difference, but much, much better performance. the 460 is just a superior engine.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Again, go 460 if you must have a V8. Personally, i love the 300 for different reasons.
Do some research, as getting the clutch to work without buying an L&L flywheel takes a little figuring. If you're running a C6, it's a no-brainer.
<o></o>
Old May 14, 2010 | 11:41 AM
  #28
BigCountry77's Avatar
BigCountry77
id like to put a 460 in my 76 f250 4x4 would the stock dana 44 hold up to the weight
Old May 14, 2010 | 12:07 PM
  #29
1993topdog's Avatar
1993topdog
i wouldn't worry about the front end. For the most part, large tires kill front ends, not dead weight under the hood. 460 isn't that much heavier than the stock V8. probably 150lbs heavier. there are plenty of stock fords out there with heavy bumper/winch combinations that do just fine under a D44
oldblue92
Dec 30, 2009 06:46 PM
jimfoxx
New Member Introductions
Jun 13, 2007 01:51 PM
caseys
Aftermarket Products
Oct 17, 2005 12:50 PM
Drof96
User Gallery & Picture Display
Mar 2, 2003 03:21 PM
whomrig
Sep 14, 2001 03:07 PM
