Hey guys,
I have a 2000 F250 with about 110k on it. I recently changed all of the COPs because I had a couple start to miss. New boots and I also changed the plugs about 20k ago. So last week it starts missin real bad and throws a code p0303. So I replace the COP on #3 cylinder and it fixes the problem. Yesterday, same thing happens and it is the same code, p0303. So I swap the plug and COP with Cylinder #1 and I am still getting a p0303 after I cleared it. I have checked for any vacuum leaks and cleaned the MAF and replaced the fuel filter. What else could it be???
Yes, all new parts. I'm wondering if it is the injector or something? Would that cause a misfire code?
Something is wrong. You replaced all cops and boots with new and its still telling you that a cop or two is bad?
And its happening on different cylinders? At different times?
No, it only happens on cylinder #3. I swapped the plug and COP from Cylinder#3 with the plug and COP that were on cylinder #1 which are fine to see if it would fix it. I was thinking that if it was a bad COP it would throw a new code for cylinder #! since I moved it there. But threw the same code on cylinder 3. So I think the COP and plug are fine. Does anybody know what else would make it throw a missfire on #3 code (p0303)??
Thanks for replying saskdiesel
Yes, the wiring harness for the cop.
We had a 5.4 do the same thing and ended up spending over $100 for the dealer to diagnose check the wiring to the cylinder. As soon as the tech moved the plug to the cop the misfire stopped.
We went back to the campground and cleaned up the connection and it eliminated the misfire.
I would replace that plug before I did anything else. Plugs can crack anytime.
