electronic ignition
Old May 11, 2010 | 05:47 AM
fire521's Avatar
fire521
electronic ignition
I have a 76 f250 4x4 that i am rebuilding, i have to tore down to the frame and have it painted, installed a new 390 in it and in the process of finding a new cab for it, I want to start the motor while everything is off of it for ease of working on it and just to make sure it will run, i know i can only run if for a few seconds without water but how can o go about hooking up the electronis brain box to the distribitor without to much hassle? I really dont want to strip out the wiring harness just to do this for a few seconds of pleasure and wrenching any help would be greatly appreciated, Thanks
Old May 12, 2010 | 01:40 PM
wabiker's Avatar
wabiker
Thats a first for me, Never heard of any type of Electronic Brain Box/Computer for these year trucks. Maybe Im misunderstanding the question.
Ahhh...yes, the DuraSpark... DOH!
Old May 12, 2010 | 02:27 PM
TexasTrash's Avatar
TexasTrash
Get your battery, and run the ground to the block. You'll need to wire the distributor to the coil (negative side) and the positive side to the battery. Hook up your starter, and you'll need to hook up your fuel line from a gas can, to the fuel pump on the engine, and from the fuel pump to the carb.
That should be all you need.
Old May 12, 2010 | 02:41 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
It will be a Duraspark. Here is a diagram for wiring it, you can rig something together. I'm getting ready to build a test stand from an old engine stand I have. Got a 250ci I want to check out.
Old May 12, 2010 | 09:52 PM
fire521's Avatar
fire521
thats it, exactly what i needed, thanks alot for the replies
Ricx
Nov 27, 2012 06:01 PM
swaybar2001
1997 - 2003 F150
Nov 20, 2012 07:29 AM
nossliw
1983 - 2012 Ranger & B-Series
Apr 24, 2012 08:07 PM
omniBOB
1978 - 1996 Big Bronco
15
Feb 11, 2009 07:12 PM
Wcpaz
Jul 2, 2007 05:05 PM
