help 460 problem
Old May 12, 2010 | 08:45 PM
fly bye's Avatar
fly bye
i bought the springs from summit racing the part number is 99893
some of the spring info closed is 120lbs 1.875 or 1 7/8
open is 328 lbs 1 .335
Old May 12, 2010 | 09:53 PM
Bear 45/70's Avatar
Bear 45/70
That ino is worthless to us. You need to assemble the stock valve train and get the valve clear open and measure the spring height with the valve all the way open. That's why they give you that info, so you can check while assembling the engine.
Old May 23, 2010 | 09:57 PM
mechanic58's Avatar
mechanic58
Pull the cam out and take a side grinder to the lobes....knock about .125 off of all 16 of em...should fix your problem.
Hardlanding
Mar 12, 2016 10:12 AM
79f1dy
Feb 21, 2016 02:17 PM
mjr46
16
Dec 15, 2015 08:00 PM
BBpwer
Mar 30, 2015 10:06 PM
Myfreeford
Feb 6, 2011 10:42 PM
