Sponsored by: Kumho
Excursion master cylinder problem
Old May 8, 2010 | 07:15 PM
Beauderek's Avatar
Beauderek
I was wondering if anyone out there can give me a nickels worth of free advice. Last night I replaced the brake master cylinder in my 2000 Excursion with the 7.3 engine. The master cylinder I got from Advance Auto didn’t come with a reservoir, which meant I had the pleasure of trying to pry the old one off without destroying it. Now, I could rattle off a bunch of excuses but none of them would be any good so here’s my question.
When I put the old reservoir on the new cylinder, it seemed like I got both tubes to fit all the way down. But today there’s a small amount of fluid seeping out. It’s not coming from the brake lines but its gathering on the bottom of the master cylinder. From what I can tell, it’s leaking from around the rear tube of the reservoir but I think that’s being caused by the FRONT tube.
I took a picture of the front tube and there appears to be a gap between the reservoir and the cylinder. I don’t know if it’s supposed to sit flush or is this gap correct. I’ve tried everything short of taking a hammer to the reservoir to push it further down but I can’t get it to budge. I’m afraid to use too much force, especially if I’m wrong.
Can someone double check your own vehicle, or as most of you will probably already know the answer to this question without having to go look, and let me know. Any advice will sure be appreciated.
OK, it appears I can't post pictures but I can tell you the gap is about 3/8 of an inch from the bottom of the reservoir to the top of the black rubber gasket the tube goes into. But the rear tube sits flush. Is this right or do I need to get the rubber mallet out?
Thanks in advance.
BigGreen7.3swap
13
Sep 28, 2014 09:21 PM
Hawk180
Dec 21, 2012 08:06 AM
markjf150
1997 - 2003 F150
Apr 22, 2008 12:53 PM
Technocrsr
Jun 6, 2007 08:27 PM
Technocrsr
Feb 17, 2007 09:13 AM
