batt gnd
Old May 11, 2010 | 01:13 PM
  #31
300 Buster's Avatar
300 Buster
Should be a bulge or something in the wire,that's the link,If the wire is hot ahead of it and not behind it ,it's blown.If you have an ohm meter,you can probe ahead and behind it to see if it has continuity.You really need a test light with an "ice pick" type probe and an alligator clip on the wire to catch ground,then you can stick the wire through the coating and see if it's got power with out skinning it or going to the next terminal.They can be bought pretty cheap and you will use it a lot.Little multimeters are also cheap($10or so)and the can check voltage and ohms,just don't put voltage to it when it's set on ohms or you will fry it.You can pick these up at any cheap auto parts or place that sells electrical supplies,and for times like this they are priceless.
Old May 11, 2010 | 03:41 PM
  #32
greyghost85's Avatar
greyghost85
i will pick one up, friday
Old May 11, 2010 | 03:44 PM
  #33
greyghost85
the big wire that comes off the solenoid and goes into the firewall, what does it do.....where does it go?
Old May 11, 2010 | 05:10 PM
  #34
greyghost85
disregard that last question, buster! my memory isn't what it used to be.....it goes to the alt
Old May 11, 2010 | 05:12 PM
  #35
greyghost85
I'll hit this a little harder, tomorrow
Old May 11, 2010 | 06:18 PM
  #36
300 Buster's Avatar
300 Buster
Hey greyghost,I don't blame you,electrical problems can be a sob,and without the information and gadgets needed,it can give you a big head ache.The bad thing is that every year it gets worse,more electronics.Now they have vehicles that change cam timing or automatically stop for things or the new Lincoln that lowers its height at high speed,all electronically.Imagine blowing your engine or stopped in the middle of the road and can't move,or dragging on bumpy roads,all because of a short or broken wire.People are always saying "change is good" (mostly political a$$ holes),but 90% of the time for me it just means more grief !
Old May 11, 2010 | 10:47 PM
  #37
greyghost85
How about the cars that parallel park themselves. Actually, what I am doing, is going simpler....but you cant make an omelet without cracking a few eggs
Old May 12, 2010 | 12:35 AM
  #38
bghnkinf250's Avatar
bghnkinf250
What is going to happen when the car that parks itself hits a ped that stepped behind the car, or malfunctions?
Everyone should have to drive an old truck with a stick and a manual choke - keeps people focused!
Old May 12, 2010 | 07:21 PM
  #39
greyghost85
well, guys.....I got spark to the cab! A wire was left off(duh)! Battery needs charging, and gotta tighten some bolts....maybe tomorrow I hear her run
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
