outside temp
Old May 7, 2010 | 08:16 PM
Ryeandwater's Avatar
Ryeandwater
outside temp
Is there a way to change the display to celcius? My new-to-me excursion shows the temp in degrees F, and my kids don't have a clue what that means. I looked in the owners manual, and no help. I'm in Canada by the way.
Old May 7, 2010 | 09:24 PM
william_04_x's Avatar
william_04_x
Welcome to FTE.
Click here.
Old May 7, 2010 | 09:29 PM
wallz's Avatar
wallz
Welcome to FTE!
It is too bad that they only thought of the top display and the climate control to change over. It would have been nice to see that on the other dials as well. I had a car that had a digital spedometer and it was nice to hit the border and touch one button to get in mph, and then vise e versa on the way home. Made driving down there a lot easier not having to look harder at the speedo.
Old May 8, 2010 | 09:11 AM
Suburban_B_Gone's Avatar
Suburban_B_Gone
Ryeandwater,
Welcome aboard!
The short answer to your question is Yes. I had the opposite problem when I bought my 2005 Excursion; I wanted temperature in Fahrenheit. Also, you are correct; it was not discussed in my Owner's Manual either.
On the automatic climate control console, press and hold the AUTO button (bottom, far left) and the DEFROST button (bottom, far right) simultaneously for two seconds, and it will toggle the display between English and Metric units of measure.
Hope that helps.
Good Luck,
-JR
Old May 8, 2010 | 12:06 PM
jh818's Avatar
jh818
Was the OP referring to the overhead computer or the climate control for the AC/heat?
Old May 8, 2010 | 11:11 PM
Ryeandwater
Thanks
Did the two button press thing, worked perfect. Thanks
Old May 10, 2010 | 09:38 AM
Suburban_B_Gone
No problem.
Good Luck,
-JR
Midstates61
1997 - 2003 F150
29
Jan 5, 2009 05:24 PM
Saigon
20
Feb 29, 2008 04:06 AM
KJLYPW
Feb 10, 2007 08:17 PM
Lucannus
Jan 17, 2005 09:58 PM
Bowcop
Dec 25, 2003 12:25 AM
