Broken down. Need quick help
Old May 12, 2010 | 09:35 AM
  #31
nissandoc's Avatar
nissandoc
Just an update. He talked to the dealer on the phone and will be taking it in. He has extended warranty and they told him over the phone that it sounded HPOP related. It hasnt acted up again since but he is gonna let me know what they do.
And the fuse was coincidence. It will start without the fuse in it.
Old May 12, 2010 | 11:05 AM
  #32
FordWrench420's Avatar
FordWrench420
They have problems with HPOP leaks, HPOP STC fitting leaks, Stand-pipe and dummy plug D-ring leaks(if equipped with later wave style oil manifold, as well as clips/rings where the oil manifold insert into injectors.
Old May 12, 2010 | 06:27 PM
  #33
cheezit's Avatar
cheezit
I think someone suggested to try that.
NO really best of luck and let us know.
Old May 12, 2010 | 06:41 PM
  #34
npccpartsman's Avatar
npccpartsman
Do we have a new tech in our forum?????
Old May 12, 2010 | 06:42 PM
  #35
cheezit's Avatar
cheezit
if we do Im so outta here
Old May 12, 2010 | 06:48 PM
  #36
nissandoc's Avatar
nissandoc
He didnt want to shut it off after it started so I didnt try it. I was outta there 10 minutes later.
Old May 12, 2010 | 06:51 PM
  #37
npccpartsman
Nope--you can't leave. It's not allowed. I'll send the FTE police to knock on your door.
Old May 12, 2010 | 06:52 PM
  #38
cheezit's Avatar
cheezit
O yes threaten me with the good humor wagon.
Old May 12, 2010 | 06:55 PM
  #39
npccpartsman
YUP--and he brings ice cream too!!
Old May 13, 2010 | 04:12 PM
  #40
FordWrench420
Not new, just haven't been on in a couple years. 3.5 years in the field, Ford Diesel Engine Master certified. Just trying to help...
Old May 16, 2010 | 07:26 AM
  #41
nissandoc's Avatar
nissandoc
He left it with the dealer and they ran a half tank of fuel through it and couldnt get it to mess up. He drove it a few times this week and it did fine. Stopped to get fuel and it wouldnt restart. By the time I got there, which was a couple hours, it started. Followed him home to see if we could duplicate it after it got hot. After sitting for about 15 minutes it would only show 29 psi ICP while cranking at 85% duty cycle. Thanks for your help guys.
Old May 16, 2010 | 11:19 AM
  #42
cheezit's Avatar
cheezit
remove and inspect ipr valve, if nothing there suspect stc fitting. that is a of corse making sure you have base oil pressure.
Hellonwheels
Mar 13, 2010 10:57 AM
Action4478
Nov 7, 2009 12:28 PM
Dan in NC
New Member Introductions
Dec 27, 2007 03:46 PM
mgdemarco
Jun 16, 2004 06:02 PM
