Tranny fluid
Old May 7, 2010 | 03:26 PM
knash0727's Avatar
knash0727
Tranny fluid
So stupid question, but how much fluid does a 96 F250 7.3 E4OD hold, and should I put a special kind in or just ATF?
Old May 7, 2010 | 04:07 PM
fordpride's Avatar
fordpride
don't know how much but it take merconIII.
Old May 7, 2010 | 08:30 PM
Red97350's Avatar
Red97350
14 or 15 quarts maybe?
Red
Old May 7, 2010 | 09:13 PM
Brown Falcon's Avatar
Brown Falcon
Depends on if you drain the torque converter or not.
Any Mercon fluid will work.
Old May 8, 2010 | 12:03 PM
redman84's Avatar
redman84
If you drain the torque converter as well mine took 16 qts this past week. Which there is no reason not to drain it since it holds the large majority of the fluid and yours, if stock, has a drain plug. I just had my lady bump the key while I was underneath to turn the flywheel until the plug was at 6 o'clock. I've heard to turn the engine by hand but to heck with that. And our trannys are rated for Mercon which you'll probably have trouble finding because I don't think straight mercon is made anymore but anything rated to merc specs OR higher will work.
Old May 8, 2010 | 04:30 PM
Brown Falcon
Mercon III, Mercon IV, Mercon V... they are all ok in our trans
Old May 8, 2010 | 04:35 PM
knash0727's Avatar
knash0727
Cool... thanks guys
Old May 8, 2010 | 04:39 PM
DRRXR's Avatar
DRRXR
Kyle if you just do the filter and the pan drain its about 8 qts
Old May 8, 2010 | 04:44 PM
DRRXR's Avatar
DRRXR
Kyle
Forgot to add-- if you pull the filter the old o-ring likes to hang up in there. Several have missed it and later the filter drops off and they loose pump prime. I had to dig mine out but I learned to look for that on this forum. Just paying it forward.
Old May 8, 2010 | 04:52 PM
Brown Falcon
Good post Rocky. I had mine stuck up in there, luckily it was bright orange so I saw it and pulled it out. Reps sent!
Old May 8, 2010 | 10:22 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is no such thing as MERCON III or MERCON IV.
You can use MERCON or MERCON V in this trans.
Old May 9, 2010 | 03:06 PM
Brown Falcon
Oops, thinking of something else... Maybe the Dexron fluids.
