Question about new timing set
Old May 7, 2010 | 06:21 AM
SoCalExile's Avatar
SoCalExile
Just got a Comp Cams Magnum 2121 timing set for my '72 400. I have the stock cam still in it. I bought it to compensate for the retarded factory timing
Which slot should the crank key be inserted to, and which mark should the dot on the cam sprocket line up with?
Thanks.
Old May 7, 2010 | 08:47 AM
wezol5484's Avatar
wezol5484
Set it strait up. How many keyways are in the crank gear? Either way, put it on the "0" mark if it's numbered. The dot on the cam gear should be at the 6 oclock mark lined up with the crank keyway at the 12 oclock mark with the number 1 cylinder at TDC.
Old May 7, 2010 | 09:02 AM
SoCalExile's Avatar
SoCalExile
The crank gear has 3 keyways: 4* retarded, 0, and 4* advanced.
Old May 8, 2010 | 11:02 AM
wezol5484's Avatar
wezol5484
Set it at the 0 mark.
farmpaw
20
Mar 20, 2016 06:41 PM
badbird
21
Feb 25, 2011 11:19 PM
lewislynn
Mar 31, 2007 03:38 PM
78 Ranger
Apr 29, 2006 01:57 PM
sphinx
Apr 28, 2005 02:44 PM
