Looks like I am leaking a decent amount of redish fluid from the rear leftish of the engine compartment. I have a 360 in a 69 ford. Am I correct in thinking that this is transmission fluid and whats the most likely culprit? I have not had a chance to really follow where the fluid is coming from exactly.
The truck is sitting. I drove it once for an hour or so then left it sitting for about a week and a half to two weeks. There was a pretty decent sized puddle on the asphalt.
TC = Torque Converter, the fluid pump inside the bell housing that runs everything.
Sometime fairly new rebuilds will leak when not driven. Also not a bad idea to drop in at a local tranny shop, not franchise, and have them take a look. If they have been around for a while most will shoot straight with you.
So after having drivin the truck everyday for the past three or four days it not leaking very much at all. Some oil drips but not the transmission fluid.
