Radio trouble *UPDATE*
Old May 6, 2010 | 11:13 PM
droppedf100's Avatar
droppedf100
I started installing an aftermarket headunit in my dads 95 F150. I hooked it up rough at first and it worked but than 2 bare wires touched and now the memory wire doesnt have power. I checked the fuses in the panel and they are good. Not sure if there are any other fuses under the hood that blew. Not sure what to do.
Old May 7, 2010 | 05:58 AM
TexasGuy001's Avatar
TexasGuy001
There may be a fuse on the back of the radio.
Old May 7, 2010 | 07:08 AM
droppedf100
Yes it has a fuse I checked that too. The radio wasnt even plugged into the harness when it happened. Hope I figure it out without running a new wire to the radio.
Old May 8, 2010 | 08:12 PM
droppedf100
I hooked a stock radio up in the truck and it does not work either. The lights come on for the radio but no power. It is the green with black stripe wire that isnt getting power. It is for the memory. The keyed hot has power as well as the illumination wire. I may have to run a new wire from the fuse box for a constant hot if I cant find the problem which kills me to do
Old May 11, 2010 | 12:27 AM
TexasGuy001
There may be an inline fuse somwhere under the dash.
Old May 11, 2010 | 04:29 PM
droppedf100
I tried to trace it back but I cant find it once it goes into the dash from the radio. Do you know where I could find a diagram? Id like to test the wire all the way back to find the problem.
Old May 11, 2010 | 04:33 PM
TexasGuy001
Haynes or Chiltons manuals might have it. Thats about a 50/50 shot.
I bet Subford has wiring diagrams.
Old May 11, 2010 | 06:15 PM
Slip ford man's Avatar
Slip ford man
I looked in my Chilton, no good! Inquire at your library's reference desk, or on E-bay for the Ford publication:
1995 ford f150 electrical and vacuum troubleshooting manual...it contains all of the diagrams
Old May 11, 2010 | 09:47 PM
droppedf100
OK the truck is not at my house so I cant check this yet but in the owners manual the #1 fuse in the under hood fuse box says audio power so hopefully that is what broke. I found a schematic online and the memory wire goes to the underhood fuse box so it makes sense. Ill let you know if I fix it.
Old Jun 30, 2010 | 01:19 PM
droppedf100
Just an update on this. I fixed it a month ago but it blew an underhood fuse. Put a new one in and its all good.
excoelis
2009 - 2014 F150
Jan 25, 2012 08:38 AM
897.3idi
Nov 21, 2011 05:41 PM
Hollywood703
Apr 19, 2010 09:28 PM
ranch67
Mar 8, 2007 05:10 PM
mustangpete1013
Jul 6, 2005 06:21 AM
