Those with AE. . .
Old May 6, 2010 | 05:06 PM
Hiflyer746's Avatar
Hiflyer746
Those with AE. . .
Go plug your truck in and tell me what your exhaust back pressure is at idle. . . and through a good power run. I've been getting some very weird numbers and I want to see what all of you are getting. Thanks!
Timmy
Old May 6, 2010 | 05:21 PM
duck fan's Avatar
duck fan
Because racetruck
I have heard that the readings from the EBPS factor into Jody's tunes so your PCM may be seeing weird #s to change the fueling
Old May 6, 2010 | 05:24 PM
Hiflyer746's Avatar
Hiflyer746
On this particular truck. . . its flatlined at 43 PSI. . . on my truck I've seen it sitting at 47 PSI. .. and i don't know if it moves from there or not. I'd be very interested to find out more.
Timmy
Old May 6, 2010 | 05:34 PM
Bonanza35's Avatar
Bonanza35
Duck Fan, Have you had to smog your truck yet! I'm sure mine will have to be done in Sept. I noticed you have a Van trubo, That doesn't have a waste gate does it, along with the other things I just want to know how you made out and what you had to do , Thanks, Chet,
I'm also in California, Norco
Old May 6, 2010 | 06:07 PM
fyrehose's Avatar
fyrehose
Timmy
At idle it should read atmospheric pressure. For my setup, WOT is 54 at 40psi of boost. Subtract atmospheric pressure and it is 40. Hope this helps
Old May 6, 2010 | 07:59 PM
Hiflyer746's Avatar
Hiflyer746
Thats more on par with what I would expect. I guess I've got a few failures on my hands unless its something that Jody messes with for tuning. . . but i can't imagine why we would mask the real numbers with a very high static number. I've replaced my backpressure tube not too long ago. . . guess I'm going to dive into this a little deeper. I think this will explain my erratic timing changes while cruising.
Timmy
Old May 7, 2010 | 03:08 AM
Visseroth's Avatar
Visseroth
How do you check the timing changes? I'll pull what I can off my truck and get it to you if you'd like. I'm still mostly stock minus my Superchip that came with the truck that I don't want to pull out because it turns my truck into a stock dog!
BURNSTOUGHFORD
2010 - 2014 Ford SVT F150 Raptor
17
Nov 24, 2014 10:57 AM
Josh MUDDIN 4Life
104
Aug 6, 2012 07:02 PM
akboy350
38
Mar 27, 2012 06:45 PM
glruff
Delaware Chapter
Mar 31, 2007 10:32 PM
05bluehog
Feb 13, 2005 02:08 AM
