410 carbs?
Old May 6, 2010 | 02:22 PM
410F-100's Avatar
410F-100
410 carbs?
I have a 410 stroker that I am working on rebuilding the top end. It allredy has heads from a 428, intake manifold and carb.. I picked up a 2X4 lowriser intake manifold with 2X500 CFM Carter AFB Competition Series Carburetors.
How much carb can the 410 use? How far can I jet the carbs down, to save a little on gas?
Old May 7, 2010 | 02:15 PM
410F-100's Avatar
410F-100
Anybody?
Carb specs are: 9504 500cfm
Metering Rods 65x52, Primary main jets .086, Secondary main jets .095, Orange power piston step up spring
Old May 7, 2010 | 02:49 PM
85e150's Avatar
85e150
Dual 4bbls and you are worried about gas?
You can run the engine a little lean, but you'll just have to go down one step at a time and read the plugs. Too lean, it won't run right, and you'll get misfires, burn a valve, hole a piston if you like.
14.7 : 1 is the magic number for air to fuel. You can run richer, maybe a little leaner, but you're not going to gain measurable MPG with jetting changes on a 2 x 4bbl set up, unless it is currently way rich.
Stand by for more replies.
Old May 7, 2010 | 09:54 PM
410F-100's Avatar
410F-100
I am not 100% worried about gasmilage, I am more worried about the 2X 500 CFM carbs being too much fuel for the engine.
Old May 7, 2010 | 11:59 PM
85e150's Avatar
85e150
Depending on cam and other build points, it will be on the high side, but should work.
Old May 8, 2010 | 12:34 AM
410F-100's Avatar
410F-100
The build was done back in the late 70's. The original owner died about 3 years ago, and the Guy I bought it from (the "step son") wasent much help. All he knew for shure was that it was the original 360 block and it, and it was stroked out to a 410 with a 428 crank.
As I tore into the engine last year I found 428 heads and intake manifold too. I would assume that he went ahead and put the cam in it too. Dident have time to check the compression ratio, I put a pushrod in wrong and bent it!! Took 4 days to get the pushrods ordered!!! It dose have really short pushrods in it though, dont know if that tells you anything or not!
Old May 8, 2010 | 02:03 AM
Bear 45/70's Avatar
Bear 45/70
These are air valve carbs, the work so that the end result is just like Holley vacuum secondary carbs and the secondaries will only open as far as engine demand, so sure you can run them, BUT and it is a big BUT with a 2 X 4 setup you will stick your fat foot in it often to just hear it sing, so don't bother with down jetting anything. Just run it. If you want to save fuel, keep the original carb and wire the secondaries closed.
Old May 8, 2010 | 08:04 PM
410F-100's Avatar
410F-100
How would my 410 run with the dual quad set up if it was still running the stock cam that came on the 360FE in 74', compared to running a cam out of a 428? How do I date what year 428 my heads and intake manifold are from? I am assuming that all parts came from the same 428.
Old May 8, 2010 | 08:45 PM
Bear 45/70's Avatar
Bear 45/70
Stock cam from an 360 compared to a 428 cam. Depends on which 428. The standard 428 used the same cam as the 390. Which would be a mild improvement, but nowhere near as spectacular as 428CJ cam. As to the heads, the standard 428 used the same heads as a 360 while the 428CJ where pretty much the same as 427 medium riser, again night and day. Get the casting numbers off the heads, between the center spark plugs.
Old May 8, 2010 | 08:59 PM
410F-100's Avatar
410F-100
I thought the 428 and the 360 heads had different valve sizes..
Casting numbers from the heads are: C4AE, and 6090G.
Old May 8, 2010 | 09:04 PM
Bear 45/70's Avatar
Bear 45/70
Well, the C4 is a 1964 head and can't be a 360 as there were none then. The 6090G is just the designation for a head. A 428 was around from 1966 thru 1970. So the first digits will be C6, C7, C8 or C9.
Old May 8, 2010 | 09:13 PM
410F-100's Avatar
410F-100
I went out and double checked the numbers, C4AE. Dose that number tell you what engine it came from?
Anything special about these heads?
Old May 8, 2010 | 11:08 PM
Bear 45/70's Avatar
Bear 45/70
The "A" means it came from a Galaxie, other than that no. but C4 heads will have large ports. That does not mean hi-performance just that early heads had big port. The engineers found out later that for street motors smaller was better because the fuel/air mixture maintained a higher velocity.
Old May 8, 2010 | 11:59 PM
draggin the line's Avatar
draggin the line
No, "6090" is the designation for a head casting. The "G" is is the revision level. The C4-G head is a standard part for '64-'65 352 and 390 engines, with 2.02 and 1.55 valves. Larger valves can be installed, if the build warrants it.
BTW, Bear, feel free to show us a C9 head casting. And, from your previous post, the CJ head was derived from the Low Riser, not the Medium Riser.
draggin' the line
Old May 9, 2010 | 12:05 AM
Bear 45/70's Avatar
Bear 45/70
draggin' the line
Keep telling me about CJ's. I owned my first on in 1969. When did you own one?
