Offroad & 4x4
Dana 50 Swap
Old Jan 31, 2006 | 08:56 PM
88bronco351's Avatar
88bronco351
Dana 50 Swap
Got a 86 F250HD, Will my dana 50 pitman arm bolt up to my dana 60 (it's from a 97 F350) or will I need a dana 60 pitman arm
Old Jan 31, 2006 | 08:58 PM
bremen242's Avatar
bremen242
I believe it will, but you will have to use that crummy inverted - Y steering setup. grab on from a F150, I am 90% sure they are the same as the 350. The 50s are different due to the funky leaf spring TTB.
Old Jan 31, 2006 | 09:04 PM
88bronco351
Thanks I can find one from a 150 easier than a 350 around here it was hard enough to find a dana 60
Old Jan 31, 2006 | 09:36 PM
78f3504x4's Avatar
78f3504x4
Yes all the steering boxes are the same, 150-250-350. You're arm will fit. You have the F3504x4 drag-link and tie-rod as well as the track bar, right?
Old Jan 31, 2006 | 09:44 PM
fishmanndotcom's Avatar
fishmanndotcom
the axle has nothing to do with the pitman arm... 80-96 F150-F350 use the exact same steering box
-cutts-
Old Feb 1, 2006 | 03:58 PM
bremen242's Avatar
bremen242
Sorry, just looked up the parts..
'85 F150 Moog pittman arm - K8755
'85 F250 Moog pittman arm - K8755
'86 F350 Moog pittman arm - K8755
guess they are all the same fo-sho.
Old Feb 2, 2006 | 02:38 PM
88bronco351
Sweet, yes I have all the steering except the pitman arm, So I will be putting in the 60 this weekend! Thanks alot guys for the help!!
Hyperactive460
WTB - Parts & other
Nov 21, 2015 06:33 PM
Pkupman82
Feb 22, 2013 06:26 PM
Randyb12
Nov 21, 2004 11:22 AM
