Oil cooler question
Old Jun 11, 2010 | 12:21 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Originally Posted by srqdiesel chef
pretty sure I have a spare set of o-rings I ended up not using when I rebuilt mine. send me a big enough SASE and I'll put them in the mail for you
Thanks for the offer ... PM sent.
-Enjoy
fh : )_~
Old Jun 11, 2010 | 12:38 PM
srqdiesel chef's Avatar
srqdiesel chef
-Enjoy
fh : )_~
check your in-box
Old Jun 11, 2010 | 01:15 PM
Festus Hagen
Methanoholic
check your in-box
Done, Got the envies setting right here and addressed, the ol'lady has the stamps in her purse, I'll have to wait till tonight to stamp them up.
Thanks
-Enjoy
fh : )_~
Old Sep 30, 2010 | 08:03 PM
geoffstowing's Avatar
geoffstowing
any links to do ths job?i have heard you need to press it back together?how hard of a job is it to do?dearlership wants to charge 150 bucks to do this.i have a press if neeeded,and can get them from stealership.?any help is appreciated.i tried youtube for videos with no luck.....
Old Sep 30, 2010 | 08:09 PM
FL-Mudd-Duck's Avatar
FL-Mudd-Duck
pressed mine by hand
Old Sep 30, 2010 | 08:19 PM
geoffstowing
so they pull aprt pretty easy?dont need anything to get them apart i take it?just put in vice and pull it apart?just wanna be sure before i jump on it.thanks for the reply!!
Old Sep 30, 2010 | 09:42 PM
oreocreaming's Avatar
oreocreaming
as far as putting the 2 ends back on, use assembly lube to help from tearing the O rings. but as far as pressing it on you can set it on a jack and set the other side under your truck bumper or something tall enough to fit under it and slowly jack it up. that will press both sides in and give you a free hand to make sure its straight.
Old Sep 30, 2010 | 09:53 PM
Festus Hagen
Methanoholic
Make sure you inspect the bore of the ends, aluminum likes to corrode leaving a rough surface that will damaged the o-rings upon assembly.
-Enjoy
fh : )_~
Old Oct 1, 2010 | 12:00 AM
87crewdually's Avatar
87crewdually
This is how I've been doing them. I end up using the hitch of my dakota p/u and a floor jack to push the ends on.
Old Oct 1, 2010 | 01:05 AM
oreocreaming
yep yep, i just raised the lift in the shop, set the cooler between one of the arms and the floor and just lowered it. they move real slow without a load so it worked out great. but since not everyone here has a car lift i figured id throw in the method that anyone can do lol
Old Oct 1, 2010 | 06:42 AM
geoffstowing
thanks guys,you all are alot of help for someone not familiar with these engines to allow them to do it themselves and not get ripped by some of the shops...dealer wanted to charge me 150 to do it,as i had them install a rear seal and do the oil pan on a engine outside the truck.i was gonna do the intake,frt cover,oil cooler.they were gonna charge me 350 to do intake,200 for the frt cover.i got them to do the rear seal,and oil pan for 185 parts included with sealant for pan,and then told them give me a price on the other stuff before they done it,and called me back and gave me those prices.makes me think they trying to make some back up off that stuff for doing it so reasonable....should have it back this morning,going to try to get it in this weekend,get this truck on the road,and make some money back.f450 rollback,bought it with a head gasket blown,bought a engine,truck has 230k on it,so figured replace the engine and it last me a while...i hope anyway.lol...i appreciate the help on this alot....great site with good people!!!
Old Nov 1, 2010 | 03:55 PM
Gryphon1962m's Avatar
Gryphon1962m
Anyone know an online source for the International part# rings?
Old Nov 1, 2010 | 07:18 PM
  #28
greywynd's Avatar
greywynd
You're pretty much out of luck there, one is a dealer only item it seems.
Jharger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jul 21, 2019 01:40 PM
howellt39
Jan 8, 2013 10:57 AM
Bonanza35
Sep 18, 2012 11:41 PM
charleswood6969
Sep 18, 2011 11:02 PM
Timberwolf
Dec 10, 2008 09:02 PM
