4 wheel disc brake conversion
Old May 5, 2010 | 04:48 PM
ricky27330's Avatar
ricky27330
Does any one make a complete 4 wheel disc brake like willwood or bear my truck is a 1973 f100 , i got 20'' rims on my truck and the caliper can be seen and i would like an after market kit
Old May 5, 2010 | 08:10 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Stainless Steel Brakes does, but rather pricey. SSBC :: SSBC Performance Brake Systems
Josh
Old May 6, 2010 | 02:13 AM
ChaseTruck754's Avatar
ChaseTruck754
yeah - that stuff is $$$$$$
You can convert the front and rear to disks for much less. It's a bit late to take the time now or I'd find a thread showing how. Do a search for 9" and disk and you should come up with a thread or 2 (or three or eight) explaining how to do it and what parts to use.
Old May 6, 2010 | 05:37 PM
Bullitt390's Avatar
Bullitt390
It sounds like he wants fancy, painted 6-pots rather than crusty factory Ford and Chevy calipers.
josh
Old May 6, 2010 | 05:51 PM
ChaseTruck754
When you get the new calipers from the parts store they are far from crusty
If he wants to throw that much $$ at it - it's his truck. I wouldn't pay 200x the price for something I can get the same performance out of for cheaper. Then again I wouldn't throw 20's on my truck either
Old May 6, 2010 | 06:14 PM
Bullitt390's Avatar
Bullitt390
These are Mustang SHO rear calipers on my 74. Not quite as sexy as some Brembos or Wilwoods.
Josh
Old May 6, 2010 | 06:25 PM
ChaseTruck754
And? Not sure why you quoted me on that.
Sure they are not as "sexy" but they do the same job, almost equally as well (wilwood aluminum calipers flex too much) and they cost a LOT less. You're paying for just the "sexy" on the others.
If it means that much to you - take the calipers apart and have the bodies cad plated or powder coated and then keep them clean. Some of the bling with the lower price tag still
Old May 6, 2010 | 06:41 PM
Bullitt390's Avatar
Bullitt390
I am just going off of the original poster making comments regarding 20" wheels and wanting Wilwoods or Baer calipers.
I suggested SSBC knowing they make the fancy calipers, but at a cost. I know full well what factory stuff can be used, but it wasn't what the OP wanted.
As for me, I couldn't care less what my calipers look like.
Josh
Old May 6, 2010 | 09:34 PM
diehardfordtruck's Avatar
diehardfordtruck
Bullet, what brackets are you using with the sho calipers?
Old May 6, 2010 | 11:12 PM
Bullitt390's Avatar
Bullitt390
I made my own, but they are patterned after the brackets SSBC sells for their 9 inch conversion.
Josh
Old May 6, 2010 | 11:20 PM
droppedf100's Avatar
droppedf100
The only thing I found on ssbc was front rotors.
Old May 6, 2010 | 11:44 PM
Bullitt390's Avatar
Bullitt390
Kit A118 is for Truck 9 inch conversions. I used their kit on a 76 F100 I had. Back in the day the entire kit was just under $600 if I remember right. Now I see it's $900+
So when I went to do my 1974 conversion I copied their brackets and got new calipers from the auto parts store. As for the rotors they are either front rotors from a Jeep CJ7 or the front rotors off of a late 70s F150. Total cost at the time was like $150! All new parts.
Josh
Old May 7, 2010 | 01:02 AM
ChaseTruck754
cj-5 rotors work well. Maybe those are the same as the CJ-7?
From what I have seen the F-150 front rotors are too big (thick) to fit in the mustang calipers.
Old May 7, 2010 | 04:06 PM
mwvdub's Avatar
mwvdub
I used a set up from Wilwood for the rear and bought new rotors with good pads for the front of my 79.
It stops pretty well but they were not cheap.
Old May 7, 2010 | 06:31 PM
Bullitt390's Avatar
Bullitt390
Ummm... am I seeing things or are those rotors toast? Got any brake pad left?
Josh
