Need a pic- OEM trailer plug mounting
Old May 5, 2010 | 11:08 AM
superduty4x4's Avatar
superduty4x4
Can someone help me out here? Trying to figure out where the OEM trailer plug was mounted on these trucks. The PO of mine had it screwed to the side of the hitch because he never used it. A photo showing where and how it is attached to the bottom of the bumper would be great.
Old May 5, 2010 | 06:53 PM
fordpride's Avatar
fordpride
mine was on a mount on the driver side frame.
Old May 5, 2010 | 08:10 PM
pjwoolw's Avatar
pjwoolw
I don't think there was anything from the factory other than the harness to attach a plug to. I'm sure there wasn't one the 86. I'll take a pic of mine as it is today and post up.
Old May 5, 2010 | 11:46 PM
Neal 97 250's Avatar
Neal 97 250
Mine was also attached to the drivers side frame. Still is.
Old May 6, 2010 | 11:06 AM
superduty4x4
If you had a factory tow package then it had a bumper mounted 7 way RV plug. I have the plug, just need to know where its supposed to be mounted (and I have to re-bend the bracket).
Old May 6, 2010 | 11:37 AM
pjwoolw's Avatar
pjwoolw
Since mine isn't the factory plug I dug up this.
Old May 6, 2010 | 12:37 PM
JamesHajek's Avatar
JamesHajek
I know my truck has the factory tow package, Ill go take a look at it after my next class and take a picture if i think its what your looking for.
Old May 6, 2010 | 01:02 PM
strokersace's Avatar
strokersace
Pete's diagram is how mine is. The wire plug is up on the frame at the back crossmember with the actual trailer connetion on the bottom of the bumper attached to a bracket.
Old May 6, 2010 | 01:36 PM
Fullcrew7.3's Avatar
Fullcrew7.3
Ditto for mine. Just like the pic.
Old May 6, 2010 | 01:55 PM
superduty4x4
Thats what I need to know- how is the bracket bent and how does it attach to the bumper. I guess I wasn't clear in my original post.
Old May 6, 2010 | 02:10 PM
strokersace
It's bent with a right angle at the top that sit's flush with the bottom of the bumper. There's a little positioning tap that keeps it in place then a 13mm bolt that screws into the bottom of the bumper.
Old May 6, 2010 | 02:54 PM
JamesHajek's Avatar
JamesHajek
These are crappy pictures but i hope they help you...
Old May 6, 2010 | 03:47 PM
MLCinNCTX's Avatar
MLCinNCTX
What you have to do to mount it will depend on the bumper you have. Just make it work. I have the bracket on mine bolted to the "step area" of my step bumper.
These trucks were shipped without bumpers and as many said the trucks with the tow package had the trailer plug bolted to the driver's side frame for shipping. The bumpers were a dealer installed item. If you bought a Ford bumper the bracket bolted right to it. If you bought an aftermarket bumper you had to be creative. Mine is to the left of the receiver tube, but still behind the cross-bar of the hitch to protect it from being hit with road hazards or brush when in pastures.
Old May 6, 2010 | 04:06 PM
superduty4x4
That's what I needed to know, thanks man!
I have the bracket bent properly (PO had modified it some) but I couldn't see any threads in the 2 round holes on the bottom of the bumper, which won't work anyway since it puts the plug too close to the hitch (I believe I even have the same hitch as you James). Now I just need to decide if I want to stick with the OEM trailer plug, or do some modifying and run the OEM plug off of a Super Duty.
Old May 6, 2010 | 06:05 PM
JamesHajek's Avatar
JamesHajek
Glad I could help.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
DetailerDave
Feb 16, 2016 08:36 PM
cusneddie
Oct 20, 2012 08:08 PM
BoLtThEhUsKy
Jun 15, 2012 07:17 PM
CA-F250
6.7L Power Stroke Diesel
Jul 19, 2011 07:47 AM
wingnutt2420
Jul 1, 2010 06:41 AM
