Fuel tank evap
Old May 5, 2010 | 02:16 AM
Phreaq's Avatar
Phreaq
Fuel tank evap
I need some help identifying this part
DOTA-9A198-F
It was pulled from inside, of what would be on a car, the left side "B" pillar.
The lines have broken. Can anyone help with these evap line routing?
1970 F100 300ci, 4 on the floor
In cab tank has vent tubes on top.
Two side tank, I'm not sure if they are any good.
Charcoal canister is present but unknown as to its current condition.
Not that I have to pass smog, but it will help keep the fuel smell down in the cab.
Old May 5, 2010 | 02:56 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Phreaq
I need some help identifying this part DOTA-9A198-F
Ford ID engineering number: DOTA-9A198-F = Ford Part Number DOTZ9A091C .. Fuel Tank Vent Expansion Tank Assy / Obsolete
Use with 19 1/2 gallon In-Cab Fuel Tank / Use w/the Evaporative Emission System.
Fits: 1970 F100 302 / The Evaporative Emission system was introduced in 1970.
This system was mandatory in all 1970 Passenger Cars, F100 302's, Bronco's & Econolines sold new in CA and maybe in other states as well.
No Ford Dealer or obsolete parts vendor has any.
Old Mar 30, 2011 | 09:39 AM
Phreaq's Avatar
Phreaq
Getting close to having a running truck again. Anyone have trouble with this thing? What is a good way to delete/replace this thing?
Old Mar 30, 2011 | 11:04 AM
Danger_Dave's Avatar
Danger_Dave
yepper its a shame they started doing all that emissions in the 70's. because prior to that cars and trucks were an absolute MASTERPIECE. especially muscle cars. its no wonder some of them bring 6 or even 7 digits at auctions. who woulda knew.
Old Mar 30, 2011 | 01:45 PM
Phreaq's Avatar
Phreaq
This is where it broke
Old Apr 3, 2012 | 09:27 AM
Phreaq's Avatar
Phreaq
To freshen up this issue, I no longer have fumes in the cab.
I had a rubber fuel line going from one evap line (tank side) to the canister line. This caused gas to fill the canister when it got hot or went around a corner. I have since looped the the tank lines together. (pictures coming soon)
I'm not sure what to do. The "jug" was some sort of Liquid vapor separator for the canister.
Also, I replaced the filler neck hose, and re-tightened the clamps. I think I have them tight now. I have a locking gas cap and I do not recall it it is vented or not. In this case I hope it is vented, as I have removed the evap/vent system.
If this all is ok, I will remove the evap canister. It is falling apart anyway.
I will also note that I have not filled the tank more the 1/2. I will be cheking into my gas cap and post back.
SideWinder4.9l
16
May 10, 2013 10:52 PM
rmodel65
Aug 18, 2011 01:58 PM
offroadracer99
Oct 22, 2010 10:22 PM
Deadkid9110
18
Jul 15, 2010 10:42 PM
opnjim
1997 - 2003 F150
Aug 5, 2009 09:09 PM
