Climate Control problem
There is a electircal box on the heater behind the gloce box says RCC on it,,,couple plugs with multi wires going into it,,,we are thinking this may be the culprit,,,there must be some Blend door that is not closing,,letting No air through the condenser,,,we can feel,,a warm side and a cold side of the heater box,,,and this RCC marked elect. box is attached right there!
I know it is Not an Excursion,,,But i know some Excursions have Climate Control,,,Maybe some one can Help ??,,,thanks,,,,,Mark
FordTaurus.net • Changed Battery, now A/C blows hot. - Ford Taurus Forum
I did find alot of Taurus heater/AC Blend doors break off and block the airflow,,,My 04' Explorer had the same problem(I called it the Fresh Air Door),,,man was it a cold ride in the winter,,,,Plus mice were getting inside through that brokeoff door !!!
Ford needs to re-think the Blend door axle's,,,thats what seems to Break off!!
