Money Pit
Old May 7, 2010 | 02:38 PM
cowmilker08's Avatar
cowmilker08
Are there any numbers on the tanks? So that i can just look at my old one.
Old May 7, 2010 | 03:58 PM
Talyn's Avatar
Talyn
Should be in your user manual if you got one.
but the numbers here are pretty close.
I generally just say 18 per tank.
But i belive the back is 18.6 and the front is 19.4
Old May 7, 2010 | 10:20 PM
oldbird1965's Avatar
oldbird1965
Originally Posted by Talyn
Glenn, money pit is something you constantly throw money into.
Buying junk is getting ripped off. =)
The front tank sizes change all the time
I never get more than 18 in my front tank, and I've ran it dry.
*shrugs*
They changed it by a gallon here and there over the years, too hard to keep track.
Dont forget how much pumps foam the fuel, we really are getting ripped when buying fuel a lot of times.
Hm i wonder? =)
They try and tweak the pumps so when you buy X amount of fuel, it starts to cheat you after so many gallons.
Thats my personal thought though.
technially you are correct Talyn, in my mind a monthly payment equals a money pit big time. That's why I stick with a 14 year old PSD!!!!!!!!!
Old May 8, 2010 | 06:36 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Aft of Axle Tank 18.2 gal (US)
Midship Tank 4 x 4 w/E4OD trans and 3378 mm (133 in) wheelbase 22.0 gal (US)
All others 19.0 gal (US)
I just want to make sure you guys saw that above post.
REGULAR cab trucks came with a 22 gallon poly tank, the only configuration with the larger 22 gallon tank. 2wd, 4wd, 250, 350, didn't matter. If it's a regular cab it had the 22 gallon. And possibly the ext cab short bed, I don't know for sure on that one.
ALL OTHERS were 19 gallon front, and all rears in all trucks were 18 - 19 gallon.
The cross member for the driveshaft carrier bearing cuts the tank short on the longer trucks. I thought about going to a one piece shaft and add the larger front tank, but as of yet the extra 3 gallons hasn't motivated me to do so.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old May 8, 2010 | 07:06 AM
Talyn's Avatar
Talyn
Mine isn't 22. And it isn't plastic. =\
Thunderhorn
1978 - 1996 Big Bronco
May 1, 2014 08:18 PM
gmenfan
Nov 28, 2010 08:01 PM
SilverSport
Jun 10, 2006 04:56 PM
dogdude2003
Oct 13, 2005 06:50 AM
Raceallday
Oct 2, 2004 04:31 PM
