2 minor things..
Old May 3, 2010 | 07:55 PM
'83f3fiddy's Avatar
'83f3fiddy
2 minor things..
so i noticed today there is a small leak coming fro ma metal hose on the driver side near the bottom..and how can i stop the power steering leak thats coming from where the res. meets the pump??
Old May 3, 2010 | 08:02 PM
fepowerguy8's Avatar
fepowerguy8
Well if it's an automatic the metal line on the bottom would be your transmission cooling lines. In most cases you are better off replacing the line then trying to patch it. Well if it's metal try JB weld, if it's plastic try some caulking that is impervious to oils and water. Or buy a new pump
Old May 3, 2010 | 08:50 PM
FordNFishinLover's Avatar
FordNFishinLover
Jb weld might work on the line. But what you can do is cut the metal line in half and get a compression fitting and it will seal it.
Old May 3, 2010 | 08:51 PM
muscletruck7379's Avatar
muscletruck7379
I would agree with replacing the pump, years back I put a saginaw off a van on my bronco and never had any trouble with it.
the other leak could be either your tranny cooler lines, power steering pump lines, or even the cooler for your p/s that is on the crossmember. I would say its best just to replace it, as a compression fitting isn't near as good of a fix.
hey FE power guy, I like your taste in cars...
Old May 3, 2010 | 08:55 PM
'83f3fiddy's Avatar
'83f3fiddy
lol so i need to blow money on a new PS pump, and i can jb weld the hose and its a dripping leak not a squirting leak lol
Old May 3, 2010 | 08:58 PM
FordNFishinLover
Lookin at around 60 for the p/s pump, and i tend to think the jb weld would hold fine. I'd just clean the surface real well too much sure it sticks.
Might not be the best fix but i think it would work.
Old May 3, 2010 | 08:59 PM
'83f3fiddy's Avatar
'83f3fiddy
well i would get that JB weld stick thing and mold it around the tube
Old May 3, 2010 | 09:21 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Put a splice in the line if thats what it is ...
As for the power steering pump, if it's the reservoir to pump, replace the o-ring!
-Enjoy
fh : )_~
Old May 3, 2010 | 10:38 PM
fepowerguy8
Muscletruck, Falcon A!! I'd love to see pics of your Falcon. My Dad is obsessed with round body Falcons, so it kinda rubbed off on me. But I still like the land yachts more, no replacement for displacement The Boss 144 just don't have the get up and go.
With the cooling lines you might get away with cutting out the bad part and putting a rubber line in place. Sometimes it causes other spots to blow through then, that's why I recommend just replacing them.
Old May 3, 2010 | 10:57 PM
fepowerguy8
Maybe something like this would help? More Information for ACDELCO 36351210
Old May 4, 2010 | 05:55 AM
'83f3fiddy's Avatar
'83f3fiddy
well its leaking at the radiator then dripping down the line and onto the lower radiator hose...thats how i saw it cause the lower hose was wet
tommy6866
Nov 24, 2014 10:25 PM
Diesel wyatt
Sep 25, 2013 08:06 PM
johnson2007
Apr 26, 2011 01:21 PM
rawn
Feb 5, 2011 07:21 AM
Windsetter
Aerostar
18
Nov 21, 2010 03:29 PM
