What should max temps be when pulling?
Old May 3, 2010 | 04:06 PM
427 fordman's Avatar
427 fordman
Just like the topic says, I would like to know what I should be watching for sure when it comes to temperatures while towing. Racing season is here and I am pulling a 48 foot gooseneck enclosed double car hauler and I know temps will become an issue, especially when it gets hot outside. I'm new to all these mods, and new to the big trailer so.........
Anyway, what should max constant temps be and max temps period for the transmission and exhaust?
Thanks guys.
Old May 3, 2010 | 06:20 PM
JamesHajek's Avatar
JamesHajek
You dont wanna go over 1200* Egt's for long periods of time (short bursts are gonna happen, just dont do it alot) and anything over 200* in the tranny will start to cook it.
Old May 3, 2010 | 07:21 PM
Brown Falcon's Avatar
Brown Falcon
Yep, what James said...
Old May 3, 2010 | 10:27 PM
oldbird1965's Avatar
oldbird1965
Also what James said. I'll lay it on 1250* pulling a grade and the trans is good for 200* like memtioned. I've added synethic trans oil and have been told your can push 210* for a while and be OK. 48', WOW, I thought my 42' was long. My son-in-law passed me on the freeway and said I looked like a semi. lol
Old May 3, 2010 | 11:31 PM
chicagodragon's Avatar
chicagodragon
i love how far back you had to get to take that sig pic. looks like a road train.
Old May 4, 2010 | 05:59 AM
427 fordman
Thanks guys. Glenn, I was thinking I'd hear from you, I knew you pulled a 42 footer and am glad for your input. I understand the semi comparison, the day I bought it home I stopped at a truckstop and parked in a line of semis and it was about the same length!
Thanks again for the advice. I thought I had the numbers right but I wanted input for sure.
Old May 4, 2010 | 06:39 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I don't agree. You can run as hot as 220°F all day long and not do any damage at all. You can go as high as 250°F for no more than 1/2 hour with no damage.
Old May 4, 2010 | 09:50 AM
Brown Falcon
Good to know Mark. Always good to have your expertise on trannies here.
Old May 4, 2010 | 10:07 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
What kind of tranny oil do you recommend?
To thouse temps are there any problem with the OEM front seal?
Old May 4, 2010 | 11:53 AM
JamesHajek's Avatar
JamesHajek
Thanks for the correction. Good to know for future reference.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old May 4, 2010 | 12:03 PM
427 fordman
Yes, thanks much Mark. I'm glad to know for sure.
Old May 4, 2010 | 01:44 PM
Mark Kovalsky
Those temps are for any MERCON or MERCON V fluid. The limiting factor for temperature is not necessarily the ATF, but non-metal parts in the trans and cooling system.
Old May 4, 2010 | 10:31 PM
oldbird1965
Mark, I stand corrected, I do now remember reading that. I just try not to push it above 210 but sometimes a guy can't help it, lol. George, yes it is a 'train'. With a 42' or 48' trailer at least you can back up. With that combination I got you can't back up more then two feet or your screwed. If I ever get trapped I'll have to unhook the trailer. Its a temp thing, I don't do it all the time! Do you like the Ford sign under the Flag?
