I was tinkering around with my 2000 2.5 the other day and forgot to hook back up an electrical connector up by the EGR valve well i drove it to work and it was cutting out badly and idling up high,when i got stopped i saw the problem and reconnected it,the truck runs good again but how do i get the light to go back off,i disconnected the negative battery terminal for a second but it still comes back on.
You have an OBD-II emissions control system. It will remember a malfunction, turn on the light, and if it does not re-occur after XX start-run-shutoff cycles, it will turn the light back off. I don't remember what XX is, but it is not a whole lot.
Try just using the vehicle as normal, and if it doesn't go off after a dozen or so trips, go to a parts house that will let you use their reader to pull the codes and extinguish the light. If it then re-occurs, pay attention to the codes.
tom
Powersmoked, I have yet to see any OBD-II tester available for less than $69, even at Harbor Freight. The only testers I have seen for the pre-OBD-II for FoMoCo cost in the neighborhood of $30.
Please post a picture, manufacturer and part number for this $20 tester from CostCo that you have recommended several times already. I am sure we all would like to see it, and "The Boss" would likely approve a $20 expenditure more readily than the $70-90 that is what I have seen test equipment sell for.
tom
tom
codekey item # 375265. 1 month ago it was $19.95 at costcos
Wish I'd seen that then... I have a brand new reader from HF that was marked down from around $100 that I got with one of their 20% off coupon deals for about $80. A $20, or even $30 reader looks like a good buy to me.
tom
I am probably going to stop mentioning the codereader/scanner idea anymore,lol, every time i do someone mentions something.... I just brought it up because some people cant afford a real scanner but the $20 code reader at least lets you see the codes and erase them. it helps to catch pending codes that go away before they trip the cel..........you probably got a scanner that does a lot more it might even read live data, pids etc,........
I'm glad you mentioned it,I never knew them things were that cheap either,awhile back at Autozone seems like they were going for around 100$ or more...
and just a reminder all it does is read and erase codes, the other more expensive ones do more........also I don't know if Costco has them anymore. I do know they had them for $19.99 about 5 weeks ago.......maybe they sold out.......next time I am there I will look......
