points & plug gap 72 highboy
Old Jan 30, 2003 | 10:45 PM
shack's Avatar
shack
Can someone tell the gap setting for the points and plugs on a 72 highboy with the 360 engine??
Thanks so much,
Joel
Old Jan 31, 2003 | 12:36 AM
krazdndenver's Avatar
krazdndenver
The gap for the points is to use a paper matches book, this is an old school method of doing this. You should be able to find the spark plug gap at the place were you bought the plugs. Hope this helps.
Robert
72 F100 Ranger XLT W/ 86 5.0L W/ AOD
www.geocities.com/krazdndenver
Old Jan 31, 2003 | 12:59 AM
390fe's Avatar
390fe
The points are gapped at .017, or 27 to 31 degrees dwell. The plugs are gapped at .035.
Old Jan 31, 2003 | 01:12 PM
ford_nut's Avatar
ford_nut
shack
what works for me is when i set the dist. roughly 10 degress BTDC and then set the points with a matchbook cover as mentioned in the prior post. I never really bother to gap my plugs either. I just buy a set of Autolite 45's, slap a lil never seize on the threads and go! So far, I have had NO problems with this method and I have YET to break down! Just make sure that when you replace the points, install a NEW matched condenser as well. I never liked timing lights because they dont take into account distributor bushing wear which has a tendency to distort actual timing results!
GOOD LUCK
regards
Ben
Old Jan 31, 2003 | 10:18 PM
speedkingf100's Avatar
speedkingf100
I have never gapped my new plugs either but my dad taught me to set the points with a worn dime.
Steve
Old Feb 1, 2003 | 12:17 PM
dinosaurfan's Avatar
dinosaurfan
Jason390fe is giving you the right numbers, but what I want to know is why are you still running points ? Your engine will be happier if you change over to something more up to date. DF
Old Feb 2, 2003 | 01:03 AM
shack's Avatar
shack
LOL! Well, I guess I'm just an old dinosaur. I guess if I put all the new stuff on my old truck, I would just as soon by a newer model.
You are going to think I'm really crazy but, I'm still running split rims!
Regards, Joel
