96 F250 Fuel Pump Problems
Old May 2, 2010 | 08:55 PM
ML190's Avatar
ML190
Just finished searching the post for this but couldn't find anything....
I've got a 96 F250 with the EFI 460 and 5spd. It's been sitting a while because it likes to die at random times but now it just won't start. It will start with starting fluid but it is not getting fuel from the tanks to keep running. When you turn the key on the fuel pumps to not come on. Also, the fuel gauge pegs out at full when you turn the key on, this does not change when you select a different tank.
I've changed the relays under the hood but that has not helped. I pulled the wiring harness connector on the firewall to check for corrosion but did not find any. Tried the inertia switch but it seems fine. Can't find any blown fuses either. Just need a few more ideas on what to check. Thanks for any help.
Old May 3, 2010 | 06:56 AM
subford's Avatar
subford
Have someone hold their hand on the Fuel Pump Relay when the key is turned to the on position.
Both the PCM Power Relay and the Fuel Pump relay should click on and then one second later the Fuel Pump relay will drop out and make another click.
Do the relays do this?
Let us know this so we can tell you what to check next.
I take it this is a OBD I non California truck, right?
Old May 3, 2010 | 10:29 AM
ML190's Avatar
ML190
Thanks for the reply. I'm at work today but will check the relays when I get home in a couple of days and post the results. Also the truck is OBD1.
Love And hope
Jul 21, 2015 07:23 AM
JessieDM
26
Mar 14, 2015 03:23 PM
cargoflyr69
1983 - 2012 Ranger & B-Series
Dec 8, 2013 11:17 AM
cityjack
Jul 13, 2013 03:22 PM
strokerspeed
50
Sep 16, 2011 07:39 PM
