Fuel Pumps running continuously, but truck is not... please help
I just want to start by saying this has been a very helpful forum- thanks everyone
This is my situation- I have a 1994 F150, 4.9 inline 6, dual tank setup. I've had this truck just under a year and the rear tank has never worked, so I've been using the front tank only. The truck has been hesitating when I give it gas from a dead stop but never had any problems running smoothly throughout the rest of the RPM range. It has been doing this since I've had it in my possession.
Yesterday, it hesitated from a dead stop like it always does, then began behaving in the same way around 20-30mph. It did this for about 5 minutes until it just stopped running. Now, when I turn the key switch to on, the fuel pump runs continuously... Oddly, when I switch it to the rear tank, the rear pump also runs continuously. I changed the fuel pump in the front tank today, and it still just runs continuously, and my truck just coughs and sputters.
I looked at all my fuel lines running from both tanks all the way to the engine and I can't see any fuel coming out of the lines anywhere... I was thinking maybe I had a leak somewhere which would cause the pump to run without ever achieving a "prime"....?
Is there a third fuel pump in this system that I'm not aware of? Has anyone had this problem before? Is there any common areas where fuel could be leaking causing the fuel pump to run continuously..?
Thanks everyone- I'm at the end of my limited knowledge of this truck
No, that link goes to an ICM. You need a PCM Computer.
Go here for more information (EEC and PCM are interchangeable).
Ford Fuel Injection EEC Computers
Thanks Everyone.
I'm not sure if this is the cause though-
I had an old Jeep that had a bad PCM, and it would run while I was cranking the truck, but would not run when I dropped the keyswitch into the "run" position. My F150 will run now in the "run" position on the keyswitch, but it runs very poorly to the point that it will stall and shut off in a few seconds and sometimes not fire at all. Would this still be caused by the PCM?
