guages
Old May 3, 2010 | 10:11 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Tom is right also, i forgot about that.
George, if you want to do something on the column you will have to make it work. look at the universal guage pods at summit and there are single pods that you will be able to make work on the column. i can't remember which ones Cody used, but his look pretty slick. how many guages do you want on the column? hopefully only 2 b/c i think that's about all thats fitting there.
Old May 3, 2010 | 11:20 PM
chicagodragon's Avatar
chicagodragon
2 max on the column. i like the dash top idea.
Old May 4, 2010 | 09:34 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Actually you can fit there more than 2, look here:
Old May 4, 2010 | 09:41 AM
chicagodragon
yes, but that is a newer model truck. ive looked on summit, they have the column pods for everything except OBS. so, travis, you are right. i will have to adapt somethig myself
Old May 4, 2010 | 09:51 AM
Talyn's Avatar
Talyn
Those gauges would look so much better matched to the dash. =(
Old May 4, 2010 | 09:55 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Here are other examples of dash mounting:
Old May 4, 2010 | 09:56 AM
Brown Falcon's Avatar
Brown Falcon
I think they would look better mounted in my truck...
I like the location of them right above the steering wheel there. I wonder if I could modify a pod like that to match the curve of the dash there. I don't even mind having the wires there. I'd run a dashpad over them.
Function over form I say!
Old May 4, 2010 | 09:58 AM
Talyn's Avatar
Talyn
I'm doing dash mountings, but custom fit and made.
Not no store bought stuff.
Old May 4, 2010 | 10:44 AM
superduty4x4's Avatar
superduty4x4
You could get fancy with a hole saw and come PVC pipe (cut at an angle on one end to tilt the gauge toward the driver) and make room for 1 or 2 in that portion of the black part of the dash to either side of the steering wheel. Trouble would be visibility while driving.
Old May 4, 2010 | 11:09 AM
Talyn's Avatar
Talyn
Chase, dont spill my project before I get it done!!!!!!!
With it on the sides of the dash there, you'll have more visibility than you get with a pillar.
That pillar makes a HUGE blind spot.
Old May 4, 2010 | 11:31 AM
superduty4x4
I didn't know what you had up your sleeve... sounds like I came pretty close though
The pillar pod in my SD never bothered me, have another one for the OBS that will be filled with Isspro gauges I got for free fifty real soon
Old May 4, 2010 | 11:34 AM
Talyn's Avatar
Talyn
Yea. I just dont dig pillars at all.
Old May 4, 2010 | 02:57 PM
  #28
TheTowingCowboy's Avatar
TheTowingCowboy
Hey this is something neat I found IDK if its what you would want dragon but I think its kind of neat.
http://www.gaugepods.com/surf_pod.html
And I was looking at an idea of 3 gauges over the radio ont he dash like you were saying (Boost, Fuel pressure, Oil Pressure) then a scan gauge, Pyro and Tranny Temp on the A pillar.
This is the pod I am going to use for on my dash when I get all the guages and such that I want.
http://www.summitracing.com/parts/SUM-G2879/
Old May 4, 2010 | 03:16 PM
  #29
chicagodragon
this is a first attempt at a column mount this is my pryo
Old May 4, 2010 | 03:41 PM
  #30
TheTowingCowboy
Looks good IMO
