Accelerator cable HELP!!!
Old May 2, 2010 | 08:06 PM
emgee's Avatar
emgee
I need to locate an accelerator cable for my 1980 F100 with a 300 ci engine, 1 bbl carburetor. The engine is not original to the truck (remanufactured/used). I can't get one from the U-pick salvage yards and my attempts to locate the cable from various parts suppliers results in the cable I get in the box does not match the online or parts counter catalogue picture that looks like mine. The cable is manufactured by Dorman (the other supplier is ATP). After looking at their web site I found one that looks like my old, broken one but it is only 23 inches long and mine is 31.25 inches long (yes, size does matter). Has anyone come across one of these? Also, do I really need the tab for the throttle return spring? If I don't this would help and maybe I can modify the wrong I got from Rock Auto. Any advice is welcome.
Old May 2, 2010 | 08:11 PM
Fordguy_1970's Avatar
Fordguy_1970
Try LMC Trucks. Its a magazine they also have a web site. They have oem parts.
Old May 3, 2010 | 05:01 AM
dustybumpers's Avatar
dustybumpers
I got the one for my 82 from ford, and it is the right one. the picture you posted is for a van.
Old May 3, 2010 | 08:40 AM
emgee's Avatar
emgee
Maybe my engine is from a van. Would that would be an E 150 or something like that?
Old May 3, 2010 | 09:46 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
EOTZ9A758A .. Accelerator Cable-29" long / Obsolete
Fits 300 I-6: 1980 only F100/350 & Bronco / 1981/82 is different, 1983/86 is different again.
KOVATCH FORD in Nesquehoning PA has 1 = 570-669-5118.
BECKMAN MOTORS in Garnett KS has 1 = 800-385-5441.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
GREEN SALES CO. in Cincinnati OH has 43 = 800-543-4959 / 513-731-3304.
Fordguy_1970: OEM = Original Equipment Manufacturer, in this case: Genuine Ford Parts.
LMC sells reproduction parts. Reproduction parts are not OEM.
Old May 3, 2010 | 11:49 AM
emgee's Avatar
emgee
Thanks Number Dummy. I'm assuming that EOTZ9A758A Accelerator Cable-29" long / Obsolete is what I need and the Ford dealers you listed have these?
I'm guessing that while the engine is newer maybe the cable is original. I'll call these people and get their email addresses so I can send them the picture. I'm hopeful that a parts guy will actually do a visual check of the actual part. I do note that my cable is longer but I'll check to see if there's slack in it.
Old May 3, 2010 | 12:10 PM
NumberDummy
Correct.
GREEN SALES CO. is an obsolete parts vendor, has the world's largest stock of Ford obsolete parts: greensalescompany.com. Green Sales will make the effort, but...
I doubt the dealers will lift a finger to help you. Most likely, they'll ignore you and your picture.
They may not have other cables to compare. Most partsguy's in today's world don't give a scheiss about older vehicles. Most know absolutely nothing about them.
Old May 4, 2010 | 01:37 AM
F-250 restorer's Avatar
F-250 restorer
I'm not trying to **** anyone off here. But sometimes when someone offers an alternative it saves me time and trouble in the future.
Could you convert to a Lokar cable by making a bracket? Easy to replace, dependable....?
Old May 4, 2010 | 08:19 AM
emgee's Avatar
emgee
That's a possibility. I can make a bracket and it's an option I've thought of. I'm not a mechanic/hotrodder but have some fabrication skills/tools. Coincidentally, my son suggested Lokar just the other day. Right now I'm wondering if the tab for a throttle return spring is even necessary. The spring runs from the tab on the cable near the ball hookup to the carb to a tab off of the blower motor shroud on the firewall.
I'm checking all available options to fix this so, I appreciate your advice.
Old May 4, 2010 | 01:42 PM
emgee's Avatar
emgee
Hooray for Number Dummy and putting me in touch with Green Sales. I sent them my picture and they do have the cable I need. Thanks a million, Bill.
Old May 10, 2010 | 07:17 PM
Fordguy_1970
Number Dummy,
I reckon tooled with original Ford tooling doesn't give you a original part. Or OEM
Old May 11, 2010 | 02:58 AM
NumberDummy
Originally Posted by Fordguy_1970
Number Dummy,
What original Ford tooling does LMC have? None.
KsCop
Feb 21, 2021 02:19 PM
RIKIL
Jul 24, 2015 01:41 PM
1986F150six
23
Dec 22, 2012 09:31 PM
Cory281
Dec 8, 2012 10:19 AM
timber_cruiser
Sep 26, 2011 10:42 AM
