1978 - 1996 Big Bronco
89 starting issue
Old May 2, 2010 | 02:32 AM
jimford1's Avatar
jimford1
89 starting issue
Why does my bronco take a thousand turns to start. 89 5.0?? Fuel pump??
Old May 2, 2010 | 03:54 AM
g_k50's Avatar
g_k50
Idle Air Control (IAC) is dirty? could be fuel pump pressure, regulator, fuel filter,
Does it start right away with Ether?
Old May 2, 2010 | 12:08 PM
greystreak92's Avatar
greystreak92
Does it run and perform as it should once it does start? Fuel pressure problems are typically noticed in performance long before they keep the truck from starting.
The IAC cleaning is a good suggestion. Just don't clean it with anything that isn't safe for factory sealed throttle bodies and O2 sensors. If that doesn't work, once it is running and up to operating temp, run KOEO and KOER tests. If there is something causing it to misfire at start up, it is probably NOT going away just because the truck started.
88/89bronco
Jan 24, 2017 05:42 PM
FordTruckfan89
Aug 31, 2016 07:48 AM
89 B2
Bronco II
Dec 2, 2015 04:06 PM
89XLTBronco
Exhaust Systems
Apr 9, 2002 02:14 AM
89XLTBronco
Mar 11, 2002 09:52 AM
