Bolt Pattern Conversion. Please Help.
Old May 1, 2010 | 10:39 PM
mchall74's Avatar
mchall74
I have a 1996 f350 I believe that I have a 8-6.5 my friend gave me some rims that came off a 2002 f350 which I believe to be 8-170mm is there anyway to convert these rims to fit my truck? I really need your help.
Old May 1, 2010 | 10:43 PM
Talyn's Avatar
Talyn
Swap the axles.
Old May 1, 2010 | 11:07 PM
pauljackmax610's Avatar
pauljackmax610
or get some adapters
Old May 1, 2010 | 11:10 PM
Talyn's Avatar
Talyn
IMO, adapters are something you use on a riceburner.
not something with stock 210 hp and 300-400 ft lbs of torque.
Old May 2, 2010 | 12:19 AM
Jacksfirstdiesel's Avatar
Jacksfirstdiesel
Ihad the same problem... traded 'em for some old style rims
Old May 2, 2010 | 07:51 AM
mchall74's Avatar
mchall74
Adapters what probelms if any could I have with those? Where can I find them?
Old May 2, 2010 | 08:33 AM
fordpride's Avatar
fordpride
i don't know of any problems but it is goin to push the wheel out another 2" are so
Old May 2, 2010 | 09:25 PM
mchall74's Avatar
mchall74
Any other suggstions?
Old May 2, 2010 | 11:13 PM
Dave Sponaugle's Avatar
Dave Sponaugle
That is about the only possible fixes.
97 and older was 6.5 on 8, 165.1 mm
99 and up was 170 on 8, 170 mm
So the difference is slightly over 3/16", just enough they will not work.
Old May 3, 2010 | 05:23 AM
Brown Falcon's Avatar
Brown Falcon
Adapters can change where the load is on the wheel bearings and cause a failure.
Old May 3, 2010 | 06:06 AM
Zookie400's Avatar
Zookie400
the bearing load changes are no greater than a dished out rim though, so how bad is it really? are people with deep rims roasting bearings? i ask because i plan on getting some wider rims with less backset to fill in the fender flares, and i dont think 2 or 3" will kill the bearings, but i havent tried yet so.......?
Old May 3, 2010 | 06:48 AM
Brown Falcon
Just what I've heard from others. No personal experience.
Adapters are expensive though. You could buy a whole new set of wheels for how much adapters are.
I only paid $120 each for my brand new aluminum wheels. Sell those and get some that will fit your truck.
Old May 3, 2010 | 07:58 AM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
I would take that with a grain of salt, I have adapters on my truck as mine has been converted and with 250k on the truck I changed my first wheel seal last summer, I looked at the wheel bearings and they are mint and threw them back into service. I've grossly overloaded my truck a few time (4000lbs lime stone) in my truck and hauled it down the highway with no issues and hauled some big loads on my trailer overweighted in the last 100k that I've owned my truck and before me it hauled a 5th wheel by the orignal owner.
Old May 3, 2010 | 09:28 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
I have seen them milled/drilled out before to fit, it's not a big deal with the right equipment.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old May 3, 2010 | 10:45 PM
Zookie400's Avatar
Zookie400
brown has a very good point, cost of mods vs. just selling and buying rims that fit. a well made set of spacers/adaptors are NOT cheap.
Hudson High
40
Jul 2, 2015 09:20 AM
armygrunt15
Jun 2, 2013 10:54 PM
larryejoh
Aug 11, 2011 09:28 AM
2006powerstroke90
Apr 17, 2011 09:34 PM
lilpig88
Jan 24, 2003 03:21 PM
