Power Steering Fluid
Old May 1, 2010 | 08:21 PM
ehgeeray's Avatar
ehgeeray
Do I need a certain type of power steering fluid? I look at the department stores and all of the power steering fluids say they are comparable with Ford, Chevy and Dodge specifications but none of them specifically mention a fluid standard. I searched the forms and found a thread that specified MD-3 type fluid... Is this critical?
Old May 1, 2010 | 08:23 PM
69cj's Avatar
69cj
Mercon V syn. is what I used. No problems after a year.
Old May 1, 2010 | 08:30 PM
ehgeeray's Avatar
ehgeeray
Is it ok to mix the Mercon V with the normal fluid?
Old May 1, 2010 | 09:46 PM
cheezit's Avatar
cheezit
mercon III or mercon V either will work and ok to mix in the p/s system.
Old May 2, 2010 | 06:49 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
Mobil1 ATF Syn works well. Funny thing...it smells just like Mercon SP.
Ford Truck Enthusiasts Forums - MoyockPowerstroke's Album: Power Steering Filter
Old May 9, 2010 | 06:08 PM
6litrefan's Avatar
6litrefan
I have some of the mercon SP...can i use that and mix in with my old steering fluid?...my level is a lil low...
Old May 9, 2010 | 06:31 PM
bismic's Avatar
bismic
I don't think I would. I think I remember a Tech saying not to ....... but then again that is just my memory ...
Old May 9, 2010 | 09:03 PM
MoyockPowerstroke
Save that Mercon SP for your tranny...too expensive to waste it, especially when that's all your tranny can use...other than LV. I would personally flush the system and use Mobil1 ATF Syn, or you could use Mercon V.
Old May 10, 2010 | 07:56 AM
69cj's Avatar
69cj
You can get the Mercon V in synthetic. Got mine at Pep Boys.
panteramatt
Oct 20, 2016 07:18 AM
Kelseed1
Oct 13, 2016 07:43 AM
rblaine9000
6.4L Power Stroke Diesel
Nov 23, 2013 03:38 PM
mike L
Oil & Lubrication
Mar 30, 2006 02:56 PM
Smith76
Mar 8, 2006 09:11 AM
