Strange Fuel tank problem
Old May 1, 2010 | 10:31 AM
seismicdrift's Avatar
seismicdrift
Hey Guys,
This is a real head scratcher for me. Just bought this 85 F250 6.9L. Went to fill the tanks because both were real low. The front took 11 gal. the rear took 5? So the guages go all the way up and when they run all the way down same thing. The really interesting part about it is that when the guages get below 1/2-3/4 tank it starts cutting out and losing power when over 1700 rpm. Obviously there is something wrong with the fuel tanks/lift pumps/guage floats? Just not sure where to start. Any thoughts from the more experienced crowd? Thanks!
Old May 1, 2010 | 10:56 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Time to either drop the tanks or lift the bed, sounds like pickup tubes and sending units.
At the fuel filter, pull the schrader valve out of the bleeder (looks like a tire stem).
Test the flow there, you should get 1/3 pint in 10 seconds of cranking, it should be a fairly air free stream, if you get lots of bubbles it's sucking air, there are several places it can suck air.
  1. Pickup tubes.
  2. Fittings on Tank top.
  3. Tank Switching Valve & Fittings.
  4. The flex line from chassis to lift pump.
  5. Lift pump.
  6. And last, likely least, the main lines themselves.
(Did I miss any places???)
Test both tanks empty as well as full.
-Enjoy
fh : )_~
Old May 1, 2010 | 11:08 AM
seismicdrift
I'll check that out
Thanks a bunch I will perform that test this week. any thoughts on the diminished capacity of the tanks themselves? or maybe just bad floats in the tanks? Thanks again.
Old May 1, 2010 | 11:14 AM
Festus Hagen
Methanoholic
I'd say a combination of Sending units (floats) and pickup tubes.
-Enjoy
fh : )_~
Old May 1, 2010 | 11:31 AM
greywynd's Avatar
greywynd
When Festus says pickup tubes, what tends to happen is the plastic on the end breaks off, making your last 1/4 tank unusable. Most people take a piece of rubber fuel line, hose clamp it to the end of the tube. Cut a 'V' in the end of the rubber so it can't suck itself flat against the bottom or side of the tank and you're good to go.
Old May 2, 2010 | 12:11 PM
seismicdrift
Again, I really appreciate the input guys. I will let you all know how it comes out.
Have Ford will tow, haul, pull or push what you got!
Old May 2, 2010 | 12:20 PM
oreocreaming's Avatar
oreocreaming
i had the same issue on both my tanks. it was the pickup tube screen. the plastic just crumbled and left me with open tubes sitting half way up the tank. ford doesnt offer them anymore, but i found some off a newer superduty. same for the front and rear. dont have the part number anymore, but it did the trick. i pulled off the bed ***go that rout, 6 bolts vs a broken back**** half full diesel tanks are heavy lol. and why mess with both tanks when you can just lift the bed quickly and fix both thanks, then bolt it back down?
Old May 2, 2010 | 12:21 PM
oreocreaming
oh, make sure you drain and vacuum the tanks out. i had so much crap settled at the bottom of my tank it wasnt even funny.
Old May 2, 2010 | 09:30 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Yes, someone in here had problems from sucking up some of the remnant pieces of the old pick up screens not to long ago.
Tugly
17
May 12, 2013 05:51 PM
Tugly
31
Mar 8, 2013 06:44 AM
redman84
Feb 7, 2010 05:42 PM
CALINLEIR
Apr 28, 2009 01:47 PM
KRAZY KRAMER
Feb 20, 2007 06:52 AM
