Minnesota Chapter Join Chapter, Leader: fordpower88
May BS Thread
Old May 31, 2010 | 07:19 PM
  #1171
dlibson's Avatar
dlibson
See ya then Troy.
Old May 31, 2010 | 07:25 PM
  #1172
DieselCamper01's Avatar
DieselCamper01
Yes there is a light.
Catch ya later Troy.
Old May 31, 2010 | 07:32 PM
  #1173
dlibson's Avatar
dlibson
Yeah, I'd see what it says first before I just replaced it. There are other things that could cause those symptoms.
Old May 31, 2010 | 07:38 PM
  #1174
DieselCamper01
Sounds good. Will the crappy scanner at the parts store be good enough you think or should I pay the local garage to scan it?
Old May 31, 2010 | 07:41 PM
  #1175
dlibson's Avatar
dlibson
It may. Otherwise you can bring it here, or I can come there and check it...
Old May 31, 2010 | 07:46 PM
  #1176
DieselCamper01
I could bring it there. Would tomorrow evening or Wednesday evening work for you?
Old May 31, 2010 | 07:49 PM
  #1177
dlibson's Avatar
dlibson
Yeah, either works.
Old May 31, 2010 | 07:51 PM
  #1178
DieselCamper01
Lets shoot for tomorrow. PM me your phone number and I will call you tomorrow to confirm
Old May 31, 2010 | 07:53 PM
  #1179
Skattracker3's Avatar
Skattracker3
Evening yall.
Here is the thought, but I had a Lumina, and had the same symptoms and it was a solenoid in the trans.
Old May 31, 2010 | 07:56 PM
  #1180
dlibson's Avatar
dlibson
It could be that Lee. The only thing that lead me away from that was he said he had to keep his foot on the gas to keep it running...
Old May 31, 2010 | 07:59 PM
  #1181
Skattracker3
That is right Dave, the only way I could keep mine running is to put it in neutral.
I noticed that Jay started a June thread early. I know that I can not count, but at least I can read a calendar.
Old May 31, 2010 | 08:01 PM
  #1182
dlibson's Avatar
dlibson
The way I read it was once in neutral it needed to be idled up.
Otherwise yes, You needed a Torque Converter Solenoid. They are pretty common too.
Old May 31, 2010 | 08:10 PM
  #1183
DieselCamper01
I didn't try the neutral thing. If in gear it needed a tiny amount of pedal to stay running. How difficult is the tranny solenoid?
Hey there Lee.
Old May 31, 2010 | 08:13 PM
  #1184
dlibson's Avatar
dlibson
They are in the side pan. There are worse things, and better things to do. Not a hard job, just putzy...
Old May 31, 2010 | 08:18 PM
  #1185
DieselCamper01
Putzy I can deal with
