luck with specific battery?
Old May 1, 2010 | 07:08 AM
KUSTOM64's Avatar
KUSTOM64
my batter just died on me after 1 year. i was just wondering if any of you guys have specific battery preferences or not. i got a crap one from auto zone for about 60 bux and it fizzled out quick. thanks for responding in advance
Old May 1, 2010 | 07:39 AM
Rusty 63's Avatar
Rusty 63
Add a battery cutoff/disconnect switch. Keeps your battery from draining due to phantom draws & gremlins. I put one on my 66 Chevelle 10 years ago & the optima red-top is still tip top. Heck - I'd suggest cleaning up the battery, putting it on a slow charge & going through your cabling first. Check the terminal ends on the cables - if the wires look corroded at all just replace them. Otherwise clean the connections & especially the ground points (engine ground studs, etc) to make sure you've got good, clean, shiny to shiny connections. Put it all back together & see if your battery is really toasted. It might be more of an overall buildup of crud in your connections..... But put on a disconnect all the same!
Old May 1, 2010 | 08:07 PM
inxquve's Avatar
inxquve
I'm an Interstate fan, myself. Don't go cheap with a battery, you get what you pay for. And yes, if it sits for extended periods, get a battery disconnect switch or unhook it.
Old May 1, 2010 | 08:37 PM
TexasTornado66's Avatar
TexasTornado66
im guessing you bought a value craft batt from autozone? there is a big difference between those and the duralast model. i have worked for autozone for 5 years and i see ten times more valuecraft come back than the duralast. you should still have at least a prorated warranty, i'd go in there and use the credit they will give you for a duralast.
Old May 2, 2010 | 01:00 AM
flipklos's Avatar
flipklos
Got one that is six years, and three trucks old!
Still starts the 64 at -20F.
Olympia drycells also seem to work good. The price is insane though.
Interstate battery for a truck.................$120
Olympia drycell.......................................$200 !
I had a walmart battery start on fire by itself, and never seen a diehard that lasts more then 2 years.
Not knocking the autozone guy here..... but I have never seen one that lasts more than a year. Got one holding my shed door open!
Old May 2, 2010 | 01:11 AM
TexasTornado66
To be honest i dont own a duralast myself, i have a interstate in my 92' ford and a optima in my 66' and both have served me well so far. but for the sake of saving a few bucks a upgrade to a better model wouldn't be a bad idea.
Ted Bell
Feb 28, 2019 11:34 AM
Gigemags05
1947 and Older Ford Trucks
Jun 30, 2014 11:10 PM
02Ford150
1997 - 2003 F150
Nov 3, 2012 12:39 PM
krisbmeyer
Nov 21, 2009 10:40 PM
jokerforever
Jan 15, 2008 11:10 PM
