Sponsored by: Real Truck
Torque Specifications for Pinion Seal Replacement
Old Nov 20, 2009 | 09:47 PM
krisbmeyer's Avatar
krisbmeyer
I own a 2006 F250. I was wanting to know if anyone has the torque specifications regarding the installation of the pinion shaft nut? Just curious....
Old Nov 21, 2009 | 08:04 AM
Tom's Avatar
Tom
You should find it here:
https://www.ford-trucks.com/forums/8...placement.html
It appears that there isn't a set torque for the nut. You have to torque it so that it requires 15 ft-lbs of torque to rotate the pinion shaft.
Old Nov 21, 2009 | 02:15 PM
cartmanea's Avatar
cartmanea
The force required to rotate the pinion is in-lbs, NOT ft-lbs!!! Also, 15 isn't a set number, if you're reassembling with a used bearing, it should be 3-5 in-lbs more than it was originally. This should be checked with a good in-lbs torque wrench (not a clicker), with the brakes removed. I would advise you have someone do the work that is familiar with differentials. Also, you should use a new crush sleeve, reusing the old one can cause problems getting the bearing preload right.
Old Nov 21, 2009 | 02:32 PM
Tom's Avatar
Tom
Thanks for the correction!
Old Nov 21, 2009 | 05:32 PM
krisbmeyer's Avatar
krisbmeyer
Thanks
I was really just looking for the amount of torque to add to the nut since I was not replacing the bearings. The task is not a difficult one and yes I removed the wheels/calipers checked the load on the nut as the pinion was spinning using a dial indicating in/lb torque wrench. I even counted and recorded the threads just to see if there would be any difference once I replaced the nut. So it's all back together and is running great. I guess I'm wondering now what is the best way to clean the vent tube for the rear axle? I want to do this because a month ago I had the left and right axle seals replaced and now I just replaced the front seal. So I'm want to make sure the vent is clean because I don't want any new seals seeping any time soon.
Old Nov 21, 2009 | 08:10 PM
cartmanea's Avatar
cartmanea
They usually get plugged near the end of the hose, so a piece of wire does the trick. I hit mine with compressed air from the inside when I had the carrier out.
Old Nov 21, 2009 | 08:25 PM
krisbmeyer's Avatar
krisbmeyer
I was thinking of using a wire in the end of the hose. But is there a one way check valve at the bottom that will prevent what I'm knocking loose in the hose from dropping somewhere I don't want it to? I just don't know how the vent works...
Old Nov 21, 2009 | 09:43 PM
cartmanea's Avatar
cartmanea
Unclip the hose from the frame first and drop it down below the axle so the dirt falls out instead of in.
Old Nov 21, 2009 | 10:40 PM
krisbmeyer's Avatar
krisbmeyer
Thanks for your help.
zrt600guy
Jun 6, 2016 02:37 PM
PJ-Hunter
Dec 7, 2015 09:15 AM
Mercury Bluz
19
Nov 1, 2010 12:21 PM
NORTHLAND06
2004 - 2008 F150
Sep 28, 2008 08:16 PM
buzzchoptop
Nov 21, 2001 06:44 PM
