Sponsored by: Real Truck
Battery Discharging
Old Jan 14, 2008 | 10:46 PM
jokerforever's Avatar
jokerforever
Cool Battery Discharging
Something is draining my battery. I haven’t been driving my Super Duty very much over the last 5-6 months. Everytime I jumped in it throughout that time it has had a dead battery. Last week I pulled the battery and gave it a good charge. I drove it a few days and it ran great but then I let it set over the weekend. Again, dead battery this morning. I haven’t had a chance to troubleshoot it but hopefully will have time tomorrow. I’m a good mechanic and know what I’m looking for. I just want to know if there are any specific problems with these trucks that I should look for.
Old Jan 14, 2008 | 11:05 PM
Hootbro's Avatar
Hootbro
I would get the battery load test before looking for anything else.
Hootbro
Old Jan 14, 2008 | 11:25 PM
G BOBKA's Avatar
G BOBKA
How old are the batteries. One that batteries cell will ruin the whole battery. I would test the batteries. What I did on my truck when the battery went away. I replaced both of them just seem like the right thing to do. If you go to the auto parts store. They should be able to test your alternator or alternators if you have two. Good luck
Old Jan 15, 2008 | 06:36 AM
03KingRanch250's Avatar
03KingRanch250
Have the batteries load tested. If one is bad then replace them both. I just replaced both of mine with Duralast Gold top 850 CCA, 1000 CA. You wouldn't believe the difference when it comes to starting the truck. Fires right up. Have them test the alternator also.
Old Jan 15, 2008 | 08:27 AM
redford's Avatar
redford
FTE Leadership Emeritus
Sounds like one or both of the batteries are going bad.
Old Jan 15, 2008 | 04:34 PM
Turbokid15's Avatar
Turbokid15
Sounds like one of your cells has dropped.
Old Jan 15, 2008 | 07:51 PM
jokerforever
FYI…I have a single battery, gas engine.
The battery was only six months old. And in that time I doubt that I put two hundred miles on it. I’ve been traveling a lot and left the truck setting at home. The battery was a yellow/gold top Duralast. I took it today and had it load checked and it came up bad. It was replaced under warranty so that solved that problem.
Now a new battery shouldn’t just go bad just setting like that so I started looking around. I found that do have a direct short somewhere. So far all I’ve eliminated is the alternator and then I ran out of sunlight. At this point it could be anywhere and I’m thinking about taking the d@mn thing it to Carmax this weekend.
Old Jan 15, 2008 | 10:04 PM
Wayne64SS's Avatar
Wayne64SS
We used to have an F250 that did the same thing... turned out to be the radio went bad and was draining the battery. I suggest pulling the radio out of the truck and then seeing if it still drains the batt.
Old Jan 15, 2008 | 10:52 PM
Hootbro's Avatar
Hootbro
Originally Posted by jokerforever
........ I found that do have a direct short somewhere. So far all I’ve eliminated is the alternator and then I ran out of sunlight. .....
How did you exactly determine that? Unless you disconnect the wire/cable from point to point, you will read back to chassi ground and not figure anything out.
Even a fresh new part can have a early failure. I would not totally rule out the battery as being the only cause.
Hootbro
Old Jan 15, 2008 | 11:10 PM
biz4two's Avatar
biz4two
Arrow
Sounds like it is time to start pulling fuses. Get your owner's manual...and figure each fuse...and go to town.
Good luck...
biz
jassonn
Electrical Systems/Wiring
Nov 1, 2015 06:10 PM
ghunt
1983 - 2012 Ranger & B-Series
Apr 15, 2015 04:52 PM
Yoam69
Apr 7, 2014 10:35 PM
paulwjax
Jan 20, 2014 11:38 AM
crestfallinman
Jan 14, 2011 11:06 AM
