Sponsored by: Real Truck
tps
Old Jan 30, 2003 | 06:07 PM
therigwelder's Avatar
therigwelder
Question tps
who makes a good TPS i bought one from auto zone a wells brand and it has crapped out within a few thousand miles and what could go bad inside of them it basically looks like a electric choke to me. maybe i am not adjusting them right some pointers on adjustment would be helpful . by the way its on a 92 f-350 7.3 diesel
Old Jan 31, 2003 | 06:26 AM
RichB's Avatar
RichB
tps
Throttle Position Sensor = TPS. The TPS is a potentiometer or in other words a variable resistor. It's function is sense the position of the throttle valve; what you called an electric choke. My suspision is your TPS is adjustable and you should get a voltmeter in there and check it. You probably need to adjust it for correct output at idle.
njtinman2
Sep 11, 2014 08:22 AM
ungerp
6.7L Power Stroke Diesel
Dec 31, 2013 01:47 PM
gearheadz80
Apr 18, 2006 04:53 PM
