runs rough when cold
Old Apr 30, 2010 | 10:45 PM
TWOSTICKMEDIC's Avatar
TWOSTICKMEDIC
My 03 6.0 runs has a rough idle when the motor is cold. The RPM’s go up and down. The truck stalls with some starts, and blows white smoke with the smell of diesel smoke. When the motor is warm I have no issues. Would this be an injection control pressure sensor (ICP) issue or a dirty EGR valve. I am in the middle of a oil cooler replacement now, so if you think it would be an ICP it would be easy to change.
Old May 1, 2010 | 05:00 AM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE Medic Since your that close replace the ICP, also the electrical connector if it is oil soaked.
Old May 1, 2010 | 09:02 AM
cheezit's Avatar
cheezit
egr valve should have the issue hot or cold so most likly no it,
icp sensor maybe.
ficm issue maybe
injector stiction maybe.
Old May 1, 2010 | 09:13 AM
gearloose1's Avatar
gearloose1
Defer to Maximum and Cheezit here...
But it doesn't hurt to:
A) clean EGR valve (if not done recently)
B) reset computers, clear all codes
C) take it for an Italian tuneup.
Note: right after you clean EGR, often a loose piece of carbon will cause an intake / exhaust valve to stick open... zero power.
Rev motor clears that.
Old May 2, 2010 | 07:13 PM
TWOSTICKMEDIC
The ICP is oil soaked. I did have a small oil leak that started a few weeks ago. I have ordered a new sensor and wire connection. Thanks for the help.
yidakimason
Sep 16, 2014 06:41 PM
yidakimason
Sep 10, 2014 01:38 PM
omahaford
23
Jan 7, 2014 03:27 PM
Raznwlvs
Aug 20, 2009 10:21 PM
Yougotthehit
Apr 6, 2009 09:46 PM
